Lighted PW switch, how?
I've always wondered why the Passenger Power window switch wasn't lighted
at least it's not on my 92S
I was junking yesterday and saw that it got added on some later model or different trim lines.
I grabbed the newer switch and unfortunately there's no place for the light pigtail to plug-in(was thinking maybe it would be hidden in the door panel some where, like fog relay wires-there but not used unless installed)
Would seem I could tap some wires in the door to power a wedge bulb
Anyone know a pair that's always hot in the driver's door. Anyone with a schematic? Anyone help me out
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdReNaLiN »</TD></TR><TR><TD CLASS="quote">I just used the power to the switch itself...</TD></TR></TABLE>
so you tapped into the power for the switch? and shared the ground?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdReNaLiN »</TD></TR><TR><TD CLASS="quote">Yeup.</TD></TR></TABLE>
Doesn't that just make it light up all the time instead of when you turn on your headlights?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboixtc »</TD></TR><TR><TD CLASS="quote">
Doesn't that just make it light up all the time instead of when you turn on your headlights?</TD></TR></TABLE>
Yea, it would have to.
There's a red & black wire going to the dimmer switch next to cruise/sunroof that is hot only when the lights are on. I think that would be the easiest way. You could just run wires along where the speaker wires go to the door.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5SpdH22 »</TD></TR><TR><TD CLASS="quote">Would it shut off when you pull the key out? If that's the case, I would say have it on all the time. It's better than running a wire all the way from the dash switches.</TD></TR></TABLE>
Yes it does shut off when you take the key out...
Definately better than running your own wire. The bulb is hardly gonna burn out prematurely :S its the equivalent of driving around with your parkers on in the day etc... how many people do you see doing that ****?
strider380
Dec 23, 2014 07:51 AM
EL Vap133
Feb 22, 2006 08:55 PM
