Valve cover nut spinning
Old Oct 12, 2008 | 06:38 AM
kornerk12's Avatar
Default Valve cover nut spinning
Well im taking my valve cover off to do a valve adjustment and on one of the nuts its just spinning. From what i remember that stud coming out is just that, a stud. Its not press fit or anything and just screws into the head so if the threads on that and the nut are screwed its not a huge deal. Hopefully its just a problem with them. However I cant get the valve cover off because that nut wont come off. How should i go about removing it ?
Old Oct 12, 2008 | 07:14 AM
AndyD's Avatar
Default Re: Valve cover nut spinning (kornerk12)
Do you have a dremel? I would use that with the cutting tool. Hopefully the std threads that screw into the head aren't the ones that are damaged.
Old Oct 12, 2008 | 08:42 AM
bluedlude's Avatar
Default Re: Valve cover nut spinning (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 &raquo;</TD></TR><TR><TD CLASS="quote">Well im taking my valve cover off to do a valve adjustment and on one of the nuts its just spinning. From what i remember that stud coming out is just that, a stud. Its not press fit or anything and just screws into the head so if the threads on that and the nut are screwed its not a huge deal. Hopefully its just a problem with them. However I cant get the valve cover off because that nut wont come off. How should i go about removing it ? </TD></TR></TABLE>
pull up on the nut, if the stud comes up with the nut then that is not what is keeping your valve cover from coming off.
Old Oct 12, 2008 | 10:31 AM
ShoofIsLudin's Avatar
if its just spinning, you can either pull str8 up on it, or try to get a flat head screw drive under the nut and try prying up on the nut while loosening it.
illmatic118
11
Mar 17, 2009 09:31 AM
butter99
Jan 3, 2009 07:49 PM
Moto DC2
Dec 26, 2007 11:59 PM
BDogggUT34
Apr 22, 2005 03:12 PM
Nishant
Honda S2000
Nov 8, 2004 10:55 AM
