How to check o2 sensor?
Old Oct 11, 2008 | 09:08 PM
93CamaroLT1's Avatar
Default How to check o2 sensor?
Is there a way to check the front o2 sensor on a 99 Si?... I got a check engine light, then I reset it, and then a couple days later it came back on, so I reset it, and then it came up again after that. It's showing up as the front o2 sensor, but the car motor runs fine. Is there a way to check it to see if the sensor is in fact going bad or if it is a wiring issue?
Old Oct 20, 2008 | 04:18 PM
BucCivicSi99's Avatar
you stick the 02 sensor up ur *** hole then you find out...hahaahh j/k...! r u using them obx bullshit sensor?.....that could b why my friend! ...same **** happen to me..buy a new one the real one..stop being cheap!
Modified by BucCivicSi99 at 5:24 PM 10/20/2008
Old Oct 20, 2008 | 04:35 PM
EJ8_Enthusiast's Avatar
wow, nice reply buc.
what code are you getting with the CEL?
mattkins91
Mar 1, 2009 02:07 PM
civicsaremean
Jul 15, 2007 07:59 PM
mr devious illusions
Jan 26, 2006 11:47 PM
CEC76
Feb 25, 2002 10:20 AM
