Progress rear sway bar noise!! plz help me out
So i just found out my sway bar was causing the creeking popping sound from the rear of my SH. I thought it was the shock collar replaced that and it did nothing. Took my sway bar off and now no noise. Freaking handling sucks bad without it. What should I do when I put it back on to stop this noise. The only thing I though of was to put rubber between all metal to metal touching. Plz help me out. Have any of you ever had this problem b4?
read this: https://honda-tech.com/zerothread?id=1388416
Which bolts holes are you specifically talking about? The 2 connected to the rear underbody of the car? So the crack was on the body of the car...
yes, and in that case it has to be welded cuz its part of the unibody obviously cant be replaced. cross your fingers and check it out
