WANTED - weight of gutted SI hatchback (EH)
Old Jul 28, 2002 | 01:51 PM
743power's Avatar
Default WANTED - weight of gutted SI hatchback (EH)
I tried the search, but couldnt find anything this specific. I know Si's weight a couple hundred pounds more than a vx or cx stock, but how much would they weigh with power steering, all interior panels and carpet, rear seats, door panels, a/c, and firewall mat removed. This also includes removing power windows and locks, (and the sunroof assembly possibly). The reason I ask is that I'm getting a deal on a '94 Si that is way too good to pass up, but the pig like weight of it is leaving me thinking of ways to put it on a diet. Thanks for the help in advance.
Old Jul 28, 2002 | 02:02 PM
POLLO's Avatar
Default Re: WANTED - weight of gutted SI hatchback (743teg)
Do a search for
EG weight
That should get you the answers.
Old Jul 28, 2002 | 05:01 PM
jdmitr98's Avatar
basically your best chance for a correct answer is to look up eg weight, then weigh everything you took out and subtract
Old Jul 28, 2002 | 05:03 PM
joeseph's Avatar
Default Re: WANTED - weight of gutted SI hatchback (jdmitr98)
Sadly for us si owners, the weight of a gutted si hb, is still more than the cx or vx .
Old Jul 28, 2002 | 05:28 PM
743power's Avatar
Default Re: WANTED - weight of gutted SI hatchback (jcnfh)
Yea, that I have noticed. What I want to know is, if you took off the rear discs, bigger sway bar, a/c, power steering, abs, power windows and locks, replaced si wheels with 13" wheels and put in the 8v or vtec e motor, would the si weigh more than the cx or vx, just by the weight of the moonroof and extra tar?
Old Jul 28, 2002 | 05:38 PM
97hb's Avatar
All the chassis weight the same. Strip everything off of a si and it would weigh the same as a vx totally stripped. I mean stripped down to the chassis.
Old Jul 28, 2002 | 09:56 PM
cj7420's Avatar
New User
Default Re: WANTED - weight of gutted SI hatchback (97hb)
Isn't there supports around the sunroof? that would be the only thing I can think of that you might not be able to remove without problems. I wonder if anybody has converted their sunroof to a lighter non-motorized type?
Old Jul 28, 2002 | 09:59 PM
43MA's Avatar
92 si hb gutted weighted in at 2170 at mission raceway
Old Jul 28, 2002 | 11:53 PM
JICsube's Avatar
Default Re: WANTED - weight of gutted SI hatchback (dark lotus)
a guy i knew put some of the flex alite window too replace his sunroof in the si...
CodyC142
10
Jul 25, 2006 08:49 AM
HarryB
26
Jul 6, 2003 06:03 PM
Backmarker
Jun 24, 2002 06:21 PM
Backmarker
May 31, 2002 04:00 AM
