stripped t-stat housing wire
i just noticed today i saw a small strip on one of the housing wires. last person to work on my car was the transmission shop. i'm not trying to point fingers.
what could be done? could i tape it up with electrical tape or buy another one?
i try to look up for the picture of it on majestic honda and couldn't find it.
can somebody post pictures of that part for me?
The 4 wires that go into 1 ring terminal? thats a ground. I assume you just mean theres a little cut in the insulation, you can just leave it alone if thats the case, put some tape on it if you really want to. To replace it you need to replace the entire engine harness.
Repalce the engine harness for a simple wire fix?
If the insulation has been cut, and you want to fix it, either:
1) Tape the wire up with electrical tape.
2) Cut that portion of the wire off, solder a new wire to the existing wire, and solder to the eyelit connector.
I don't recommend wire connectors, they can corrode, or come loose.
streetstylenperformance
Feb 26, 2004 03:28 PM
