H22 with Garrett 60-1?
Old Oct 11, 2008 | 05:13 PM
tunerraceteam's Avatar
Default H22 with Garrett 60-1?
Yea im in the middle of turboing my h22, i have mahle gold series pistons pushing 9.1 comp. I have a stock head with 3 angle valve job, im aiming for 400hp and was wondering if a garrett 60-1 would be a good turbo for me
Old Oct 11, 2008 | 11:48 PM
H22Luda720's Avatar
Default Re: H22 with Garrett 60-1? (tunerraceteam)
I personally think the 60-1 is an excellent choice for an H22 assuming it is built to handle such a turbo.
More build specs?
Old Oct 12, 2008 | 02:11 AM
jDMJeRk's Avatar
Default Re: H22 with Garrett 60-1? (H22Luda720)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Luda720 &raquo;</TD></TR><TR><TD CLASS="quote">I personally think the 60-1 is an excellent choice for an H22 assuming it is built to handle such a turbo.
More build specs?</TD></TR></TABLE>
Built for the turbocharger? What are you talking about... whats wrong with low boost on even stock internals?
Old Oct 12, 2008 | 10:37 AM
Hulk22's Avatar
what hot side a/r are you running? street or track car? or both? because that should determine what turbine housing a/r you should run. what kinda spool you are looking for? a 60-1 is good beefy turbo that like the 15-22lbs of boost but maybe a bw2XX turbo.
but all in all you should think about what you want exactly then make your move.
Old Oct 12, 2008 | 08:03 PM
its a h22 with 9.1 mahle internals, fully balanced to 10,000 rpm, it has a solid deck, and its a garrett 60-1 with a Compressor Ar. 70 and the exhasut housing is a/r .63, with a compressor wheel of 60mm inducer and 82mm exducer, im shooting for a street/ track car, low boost for daily driving and like 15lbs for some track fun
Old Oct 13, 2008 | 08:40 AM
tony413's Avatar
Default Re: (tunerraceteam)
you will love that set-up
but if your reving to 10K on an H-series get a .82 a/r exhaust housing
Old Oct 13, 2008 | 09:02 AM
streetracer6rpt's Avatar
Default Re: (tony413)
H power tends to drop off before 9k.... no need to rev that high
Old Oct 13, 2008 | 12:18 PM
AmauryR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">you will love that set-up
but if your reving to 10K on an H-series get a .82 a/r exhaust housing </TD></TR></TABLE>
I have a 60-1 .82 hotside on mine, reving to the stock rev limit and the car is a blast to drive. hth.
-l8r
turbo boost
Sep 15, 2006 12:40 PM
jdmbb6-t
Aug 3, 2006 12:32 PM
kagee
Apr 5, 2006 05:22 PM
DS1
Oct 23, 2002 10:56 AM
