CEl coeds what could be causing them
Old Jul 28, 2002 | 01:39 PM
Qwikrex's Avatar
Default CEl coeds what could be causing them
okay, my ECU is throwing 3 codes. Here they are:
-Code 20, Electrical Load Detector circuit: open or short in ELD circuit, defective ELD circuit
-Code 41, Primary Heated O2 sensor heater circuit: open or short in Primary O2 sensor heater circuit, defective Primary O2 sensor heater circuit
-Code 65, Secondary Heated O2 sensor circuit Open or short in Secondary Heated O2 sensor circuit, defective Secondary Heated O2 sensor circuit
All codes seem to be realted in some way. Any ideas on where to check for a short etc.?
[Modified by [VTEC]TL, 10:39 PM 7/28/2002]
Old Jul 28, 2002 | 02:58 PM
DR. ON POINT's Avatar
Banned
Default Re: CEl coeds what could be causing them ([VTEC]TL)
do you have a test pipe?
do u have exhaust?
Your car is OBD 2 correct?
What mods do you have done to your car?
Old Jul 28, 2002 | 03:31 PM
fixhondas's Avatar
Probably a blown fuse- look under dash at fusebox for speedo fuse- probably a wire chafing under the intake manifold bracket.
924drb20
Dec 14, 2010 10:36 AM
Qwikrex
Jul 29, 2002 10:46 AM
Qwikrex
Jul 29, 2002 10:45 AM
Qwikrex
Jun 22, 2002 01:04 AM
