Cracked hose above Thermostat [PICS]
Old Oct 11, 2008 | 02:22 PM
mullenium's Avatar
Default Please HELP! Cracked hose above Thermostat [PICS]
Today my 02 Accord SE started to overheat, i noticed the lower rad hose is way cooler then the upper hose so does that mean bad thermostat?
There was a hissing noice coming from the general area near the thermostat housing. Looking closer i found this crack in a small hose above the thermostat which is spurting coolant all over the place.
Anybody know what this hose is called??
will tape or possible superglue fix this crack till i can get to a auto parts store?
also do you think it cracked because the t-stat stopped working so it got too hot?
Modified by mullenium at 4:14 PM 10/11/2008
Old Oct 12, 2008 | 02:36 PM
DC2xFIEND's Avatar
lower radiatior hose? i suggest u replace the hose before u [freak] up the rest of the cooling system. its only around 10-30 bucks anyway
Old Oct 12, 2008 | 03:08 PM
gianinline's Avatar
Default Re: (DC2xFIEND)
I believe the hose you're talking about is the #4 on this picture, called "hose B, breather heater", shouldn't cost more than 2 dollars.
zx92027xz
19
Jan 15, 2014 04:36 AM
MallyMall7
Mar 31, 2012 06:09 PM
lilshady6796
Jan 15, 2009 11:02 PM
zdizzle
Mar 10, 2008 10:50 AM
