compression test results
Old Jul 28, 2002 | 01:19 PM
Brian_92GSR's Avatar
New User
Default compression test results
I have good compression on cylinders 1-3 at around 210 psi, but cylinder 4 is only 165. I added a little oil into the combustion chamber and it read normal, a bit above 210. Is it possibile that the rings just aren't line up correctly or do they definately need replaced? The rings only have a couple thousand miles on them, which is why I ask.
Does anyone know where I can get a set of 84.5 mm rings quickly? Should I go with wiseco which is the piston I have, or what?
Old Jul 28, 2002 | 08:37 PM
New User
Default Re: compression test results (Brian_92GSR)
Anyone?
Old Jul 30, 2002 | 04:18 PM
Bontke's Avatar
Was the engine cold or hot for the CR test? With a cold engine the rings/pistons aren't hot and swelled to fit the cylinder and you get incorrect readings. The CR test is supposed to be done on a warm engine.
Old Aug 1, 2002 | 09:01 AM
New User
Default Re: compression test results (Bontke)
Right, and that would be even more true with forged pistons. It was on a cold engine (the engine was out of the car). However, I wasn't looking at the actual numbers, just the difference between the numbers. One was defintately quite a bit lower than the others, and adding oil did put it up to normal psi, meaning it was the rings.
Old Aug 1, 2002 | 08:38 PM
bob01721's Avatar
You got it!
02BladeRider
Jul 7, 2017 05:49 AM
gooblinn258
May 30, 2014 12:20 PM
Tysnet
25
Sep 26, 2011 06:55 PM
kpjo4
Jan 8, 2010 07:38 PM
birz
Apr 28, 2004 07:45 AM
