Messed Up Front Shock Bushings
My car was making these weird clicking noises coming from the front, so i decided to check everything out. I found this:
(tiny red lines were added for dramatical purposes)
As you can see, they need replacing...
I am going to purchase the Energy poly bushings due to the bushings not being sold at the dealership and mugen bushing being TOO expensive.
Now my questions:
Will i need to change out the other bushings in the arm due to a change in material?
And what special maintenance is required with these specific poly bushings?
Modified by xd69 at 9:22 PM 10/12/2008
Now my questions:
Polyurethane bushings are junk. They will squeak, they bind, and will generally wear out in a relatively short period of time when subjected to normal street use.
Look on eBay for HardRace hard rubber bushings. Similar to Mugen but cost much less.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">Polyurethane bushings are junk. They will squeak, they bind, and will generally wear out in a relatively short period of time when subjected to normal street use.
Look on eBay for HardRace hard rubber bushings. Similar to Mugen but cost much less.</TD></TR></TABLE>
Thanks for the reply!
After doing hours of searching, i did conclude that i am going to get the all the front bushings + RTA bushing from HardRace. But the thing is, i need to change that bushing ASAP, and at the time i do not have the funds to purchase and install them.
I need to pay to get my rear disk conversion done, and a few more things to finish the remodeling right now. The bad things ive heard about poly is that they do not last, but since they should only be installed for a few months, they should be fine.
And for anyone reading this with the similar problem, read this thread:
https://honda-tech.com/zerothread?id=2388838
what exactly are you trying to highlight about whats wrong with that bushing?
the pic is so crappy i cant tell, but it looks fine to me.
and dont get poly. get an oem replacement and have it pressed out and in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">what exactly are you trying to highlight about whats wrong with that bushing?
and dont get poly. get an oem replacement and have it pressed out and in.</TD></TR></TABLE>
You try getting a good pic of that area without removing any of the brake components. Not to mention i was using a crappy cell phone camera. But the bolt that goes through the bushing is CROOKED. The fork actually touches the LCA on turns with a bump!
The Internet Tough Guy
Oct 25, 2003 07:47 PM
