b16 compression test
Old Oct 11, 2008 | 07:32 AM
flaxx0r's Avatar
Default b16 compression test
well just ran comp test for first time and i got
190
160 (1st try) 170 (2nd)
190
190
i dont have access to run leakdown atm but any ideas why its so low?
no smoke at all.. =/
Old Oct 12, 2008 | 09:23 PM
mabbiker's Avatar
Default Re: b16 compression test (flaxx0r)
tell you the truth im still not a little to sure on it but every motor ive had has done the same thing to me its a little normel for it to do that if the car motor was cold it wont give a right reading but as it warms up it will gave the right reading
Old Oct 12, 2008 | 11:24 PM
flaxx0r's Avatar
it was def warm. seen that +/-20 is max for distance between cylinders..
is it something i should be consernd about?
Old Oct 13, 2008 | 03:00 AM
salman's Avatar
Default Re: (flaxx0r)
Healthy b16 makes about 210 Psi,
The manual says 183 psi, with a difference of 28 psi max between cylinders is ok...
mean if cylinder 1 is 218
and cylinder 2 is 190, its not some thing to be worry about, difference below 180 psi, means new rings and some time worse...
but here people including me wont bear cylinder difference more then 15 psi or may be less.
Your cylinder #3 is 13 psi below the healthy engine spec according to the CRX service manual,
the least cylinder compression is 135 psi,
If your not running this car for racing, its nothing to worry about, even if your are ull get around 1 to 1.5 cars faster @ 1/4 if u resolve this issue..
your ok man,
fixing expense starts around 500$ plus, completely depends upon you,
I am also learning, but i have gone through this problem that why i an sharing my experience with you.
Old Oct 14, 2008 | 09:31 PM
flaxx0r's Avatar
wow maybe i need to see if the car was warm enough when i ran the test and try it again if it was that low.
for the most part the power is there minus the auto pr3 its using atm. >.<! thanxs for the reply though xD
Old Oct 14, 2008 | 10:31 PM
salman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flaxx0r &raquo;</TD></TR><TR><TD CLASS="quote">wow maybe i need to see if the car was warm enough when i ran the test and try it again if it was that low.
for the most part the power is there minus the auto pr3 its using atm. &gt;.&lt;! thanxs for the reply though xD</TD></TR></TABLE>
Daaam, Auto...
delsolo95
Apr 3, 2013 08:49 AM
ryanangelo212
Jul 25, 2012 07:02 PM
D16SiHatch
Feb 1, 2009 10:27 AM
hondakevin21
16
Apr 25, 2006 07:43 PM
Chubz
Jun 27, 2002 02:00 PM
