Energy Suspension Bushing Questions.
Old Oct 11, 2008 | 02:58 AM
My_EFsedan's Avatar
Default Energy Suspension Bushing Questions.
since ive done so much on my car, ive thought about buying the Energy Suspension bushing kit for my car. a 91 civic sedan. i assume the crx/civic kit will work.
the kit includes
ok Front Control Arm Bushings
?? Rear Control Arm Bushings
?? Front Strut Rod Bushings (verify where this goes please)
ok Front Shock Mount Bushings (verify where this goes please)
ok Rear Shock Mount Bushings (89-91 Only) (verify where this goes please)
ok Front End Links Set
?? Steering Rack Bushings (verify where this goes please)
?? Transmission Shifter Stabilizer Bushings (manual tranny)
ok Ball Joint End Boots
ok Tie Rod End Boots
i know i cannot use the shifter bushing cause it says it for a D-series. i have an LSV with hasport shift linkage. Which shifter bushing kit am i suppose to buy? (model/year)
i have Blox rear LCA. its bad cause the bushing for the struts are torn to ****. i dont have money for Skunks or higher brands. im wondering will the "rear control arm bushings" that is included with the kit fit the Blox LCA?
i also have the 88 crx si rear sway bar on my car. what is the size of the bar? so i can also get the bushing set for that. my car is a stock DX front sway whats the size of the front?
i came across this thread in the Fa-q
https://honda-tech.com/zerothread/1986828
but i cannot open the files. or dont know which program to open with..anyone with info please help.
Old Oct 11, 2008 | 12:22 PM
My_EFsedan's Avatar
Default Re: Energy Suspension Bushing Questions. (My_EFsedan)
up
Old Oct 11, 2008 | 01:49 PM
sgallagher's Avatar
Front strut rod bushings are used to mount the strut rods to the front subframe. The strut rods are the bars coming off the front lower control arm to the front subframe.
The front and rear shock mount bushings are mounted in the cap of the strut.
Steering rack bushings mount the rack to the rear subframe(behind engine, front of car).
Shifter bushings should not matter. Should be the same.
Rear control arm bushings probably will not fit the BLOX arms.
Thats all I got for you man. Make sure you preload suspension before tightening to prevent premature wear and shitty ride.
P.S. I prefer Honda rubber bushings or the Mugen hard rubber.
Old Oct 11, 2008 | 02:18 PM
My_EFsedan's Avatar
Default Re: Energy Suspension Bushing Questions. (sgallagher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgallagher &raquo;</TD></TR><TR><TD CLASS="quote">Front strut rod bushings are used to mount the strut rods to the front subframe. The strut rods are the bars coming off the front lower control arm to the front subframe.
P.S. I prefer Honda rubber bushings or the Mugen hard rubber. </TD></TR></TABLE>
great answers. how much are the honda rubbers or Mugens?? any better or same as ES?
and the blox, i have no choice but to get new ones? what about that goo like thing people use to reinforce their motor mounts but its not the inserts? apply, let it dry and it solid..i dont know what its callled. can i use that for my bushing on my LCA?
Old Oct 11, 2008 | 06:58 PM
sgallagher's Avatar
Honda bushings are quite pricey. Check out majestic honda online for pricing.
Mugen bushings are very pricey. I've got em through out my entire suspension and motor mounts. check out KingMotorsports.com for pricing.
IMO poly bushings are crap!!
Old Oct 11, 2008 | 08:57 PM
91civiccross's Avatar
I've learned the hard way to never use Poly on the lower front arm.
The inner most bushing destroys itself after several months of hard driving (autocross and track days).
Poly does not "stretch" back into shape either.
Old Oct 13, 2008 | 10:31 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My_EFsedan &raquo;</TD></TR><TR><TD CLASS="quote">i also have the 88 crx si rear sway bar on my car. what is the size of the bar? so i can also get the bushing set for that. my car is a stock DX front sway whats the size of the front?
rear Si bar is 15mm.
front DX and Si hatch/crx (same) bar is 18mm. but ALL SEDANS have 19mm front bar.
there is no 16mm front swaybar. just HF 17.2mm. STD hatches dont have front swaybars.
Old Oct 13, 2008 | 12:00 PM
My_EFsedan's Avatar
Default Re: Energy Suspension Bushing Questions. (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
there is no 16mm front swaybar. just HF 17.2mm. STD hatches dont have front swaybars. </TD></TR></TABLE>
thank you SiR! but since people are saying ES sucks..i dont know which direction im heading now..oem and mugen as stated would probably run my pocket..
skill178
Oct 30, 2011 08:08 PM
cheap2
Suspension & Brakes
23
Apr 17, 2010 07:29 PM
cannan
Suspension & Brakes
Dec 14, 2006 06:09 PM
e-honda
Sep 8, 2006 02:28 PM
