cel 43
Old Jul 28, 2002 | 12:23 PM
Buckshot's Avatar
Default cel 43
ok my check engine light comes on periodically so i checked what it was and cel 43 came up..
so i looked up what that meant and it has something to do with the fuel system
i was woundering if anyone else had this problem and what they did to fix it cuz my car is running like ****!
i have a 94 gsr if that matters...
Old Jul 28, 2002 | 12:28 PM
neo1z's Avatar
Default Re: cel 43 (MilanoGeeSR)
try running some injector cleaner
Old Jul 28, 2002 | 12:30 PM
Buckshot's Avatar
Default Re: cel 43 (neo1z)
thanks but i tried that already...didnt make a difference, im goin to check the fuel filter now and see what that does
Old Jul 28, 2002 | 01:44 PM
bullz's Avatar
Check for vacuum leaks
Old Jul 28, 2002 | 06:49 PM
GSR901's Avatar
Default Re: cel 43 (illestjr)
maybe tighten the gas cap.
Old Jul 28, 2002 | 09:58 PM
Buckshot's Avatar
Default Re: cel 43 (B18Cwon)
ok i changed my fuel filter and there is no difference...
checkin my vacuum lines sounds like a good idea, haha but i dont know what ones to exactly to check
can anyone else spread me some knowledge?
Old Jul 29, 2002 | 01:13 AM
ShiftDown's Avatar
Yeah, 43 is an O2sensor code.... which means that you are most likely running in safe mode (full rich) which would also explain why your car is running like ****. If so, then you'll probably notice a dramatic DECREASE in gas mileage.
David
Old Jul 30, 2002 | 10:14 PM
Buckshot's Avatar
Default Re: cel 43 (Oki_Doki)
what things exactly make up the fuel system that i can check?
THE ONE
Sep 20, 2008 03:53 PM
fitbmx86
May 20, 2007 04:59 PM
str8JDMteggy
Jan 28, 2007 11:23 PM
DSeriesBeeKilla
Nov 14, 2002 12:33 PM
kento
Dec 30, 2001 04:18 PM
