how to change auto to manual transmission in a 94 integrs rs
Old Oct 10, 2008 | 05:02 PM
hondadude567's Avatar
Default how to change auto to manual transmission in a 94 integrs rs
i have a 94 integra rs and would like to change the transmission frm auto to manual how can i do it and is it a ton of work . plzz respond and thank u all !
Old Oct 10, 2008 | 05:09 PM
BoSox46GSr's Avatar
Default Re: how to change auto to manual transmission in a 94 integrs rs (hondadude567)
https://honda-tech.com/zerothread?id=273253
Please search, it took me 30 seconds to dig that out of the FAQ
Old Oct 10, 2008 | 05:19 PM
yc_dc4mar's Avatar
Default Re: how to change auto to manual transmission in a 94 integrs rs (BoSox46GSr)
there is more than plenty of information on this forum for you to search and this question is asked about once a week in here. ive done the research and swap myself.
Old Oct 10, 2008 | 05:32 PM
ight well how much does it cost over a 1000 or less?
Old Oct 10, 2008 | 05:46 PM
projectac's Avatar
unless you have some time and money into it already , if not dont.
sell the auto and get a 5 speed..
Old Oct 10, 2008 | 05:53 PM
yc_dc4mar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude567 &raquo;</TD></TR><TR><TD CLASS="quote">ight well how much does it cost over a 1000 or less?</TD></TR></TABLE>
it really all depends. when i was doing it i paid 500 for the tranny and i got alot of the other stuff for free from friends who had extra parts laying around. but just think about it... cost me under 1000 probably like 850 with tones of free parts.
tranny and starter
shift linkage and everything that goes with it
shifter and shiftboot
clutch
flywheel
pressure plate
throwout bearing.
clutchfork
clutch lines
master cyl for the clutch
slave cylinder
tranny mounts
manual ecu
manual wiring harness(you can use automatic one. you will have extra plugs though. its what im doing)
manual gage cluster (try to get from same year.)
alot of re wiring. for reverse light, cruise control, and starting.
also if you didnt know, the tranny mount on the tranny side, the part thats part of the car will either have to be cut off and weld on one from a manual car, OR innovative mounts makes an auto-manual conversion bracket mount you can buy. i would get the mount. i did the welding on thing and it kinda got crooked. nothing wrong but it could have been worse.
im sure im missing some stuff so do some more research, but i pretty much got you started there
Old Oct 10, 2008 | 05:54 PM
yc_dc4mar's Avatar
Default Re: how to change auto to manual transmission in a 94 integrs rs (projectac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectac &raquo;</TD></TR><TR><TD CLASS="quote">unless you have some time and money into it already , if not dont.
sell the auto and get a 5 speed..</TD></TR></TABLE>
i would listen to this guy as well. i regret doing it. my car came out clean and everthing is how i wanted it to be. but i regret dumping that much money into a nearly 10 year old car.
and if you figure prices out. its going to be over 1500 in parts if you have to buy everything.
Old Oct 10, 2008 | 06:38 PM
SleeperGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude567 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 94 integra rs and would like to change the transmission frm auto to manual how can i do it and is it a ton of work . plzz respond and thank u all ! </TD></TR></TABLE>
If it was 1994 this probably would have been a good move. IMO you're a little late with that move. I mean K swaps are getting to be old hat. If you are going to go through all the trouble to change the tranny, you might as well tear down to the shell and do a ground up build. Again just my opinion, i'm sure some people will tell you how simple it is to swap the tranny.
Old Oct 10, 2008 | 06:51 PM
vietnamezerice's Avatar
Default Re: how to change auto to manual transmission in a 94 integrs rs (SleeperGSR)
i have a converted DB... I love my car
akces
Oct 19, 2008 09:59 PM
nix94delsol
May 2, 2007 09:07 AM
tuner6r
15
Mar 20, 2005 09:45 PM
