left side of my gauge cluster isnt lit up and temp gauge doesnt work in my db8
Old Oct 10, 2008 | 12:10 AM
rollinonblades's Avatar
Default left side of my gauge cluster isnt lit up and temp gauge doesnt work in my db8
i've never had a 3rd gen teg before, so its new to me. i've had the 2nd gens.. anywa i bought the car and the left side lights of the gauge cluster wont turn on and the temp gauge looks as is if never changes when the cars turned on and warmed up. it just sits that at a little below cold... just wondering if anyone knows of a quick fix for that or what im going to have to have done... thanks
Old Oct 10, 2008 | 06:35 AM
AWD Terror's Avatar
Default Re: left side of my gauge cluster isnt lit up and temp gauge doesnt work in my db8 (rollinonblades)
Could just be a bulb out. Maybe a weekend at most fix.
Are you sure the car is warming up? Check the lower coolant lines to see if they are as hot as the top. You may just need a new thermo
Old Oct 10, 2008 | 01:32 PM
SoTexDC2's Avatar
Bulbs are located on the back of your gauge cluster. Easy fix.
If the temp gauge isn't working, on the left side of your head, next to the ECT sensor is a smaller coolant temp. sensor. Use a volt meter and check that, as well as the wires to the gauge.
Old Oct 10, 2008 | 09:41 PM
vietnamezerice's Avatar
Default Re: (SoTexDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoTexDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Bulbs are located on the back of your gauge cluster. Easy fix.
If the temp gauge isn't working, on the left side of your head, next to the ECT sensor is a smaller coolant temp. sensor. Use a volt meter and check that, as well as the wires to the gauge.</TD></TR></TABLE>
i couldn't have said it any better
Old Oct 14, 2008 | 02:49 AM
so yeah i realized that it does work, when i turn the key on and the car, the temp will go up a bit and drop back down. so more or less its constantly running cold.... so i dont know whats up with it... and also the heater never warms up all the way... and the fan is ALWAYS ON. from when i turn the key forward to however long im driving... it doesnt turn off.. oh and its weird that my car doesnt turn off right when i turn the key off... it'll stay on for like a second or so... and i dont have it turbo'd or anything its stock.... i dont know, this car has alot of weird issues i gotta figure out.
2k_Si
10
Jan 28, 2009 10:32 AM
jdmxsoles
Jun 11, 2007 12:56 PM
Mrfeee1
Oct 7, 2004 08:40 AM
