Viper 791xv install help please. Couple of Q's...
Ok, installing the alarm with remote start option hooked up. The 4 wire harness that plugs into the satellite relay box isn't very well addressed in the online guides and install guide. From what I've read, the blue one can be used for the clutch switch when the rear defroster is already taken, but I'm not hooking that up. So can I use the H3/5 blue/white wire for the clutch switch bypass?
Also, do I need to hook up any of the other wires on that 4 plug harness the plugs into the satellite? Unless I'm mistaken the 10 gauge red, purple, green, pink, and orange wires are used to connect to their corresponding wires, right?
Thanks in advance!!!
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Make and model of the car. And if this is a 5 speed your thread will be locked unless your using a 5 speed netrual saftey switch.
Yeah, I'm also doing the e-brake and manual toggle switch for the black and white wire. It's a 92 civic sedan.
The blue wire is your status output which will be used for your clutch bypass mod. The pink (ignition) purple (starter) orange (accessory) will only be used if you needed to add a relay for a second/third ignition, second/third accessory, and second starter. Luckly you have one of the easiest cars to put a remote start in.
wrx-killer-Sti-eater (4:41 PM 10/20/2008):
Thread Edit Notification
Your thread Viper 791xv install help please. Couple of Q's... in forum Audio / Security / Video has been edited.
The thread is now locked.
Comment: Until you add a dei 689m saftey bypass, this thread will be locked so you don't hurt you or someone else
notfastenough (4:53 PM 10/20/2008): Next to the last post by me: Yeah, I'm also doing the e-brake and manual toggle switch for the black and white wire. It's a 92 civic sedan.
That was responding to your post above it. But don't worry about unlocking it now, I figured it out. Thanks for nothing anyways.
wrx-killer-Sti-eater (10:00 PM 10/20/2008): What you have does not do squat. If you do not have this your thread will be locked
http://www.al-eds.com/Directed....html
What you have does not prevent the car from starting in gear.
notfastenough
When you hurt someone or tear up the front end of your car don't say we did not warn you.
notfastenough
compint
Mar 24, 2007 12:44 PM
compint
Mar 13, 2007 10:42 PM
