Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
wheel size help!
Old Oct 9, 2008 | 05:45 PM
ajpturbopittsburgh's Avatar
Default wheel size help!
Posted before but maybe something was wrong because I didn't get any replies.
But does anyone know if a 245/3518 will fit. I have a sedan and I put the hfp sports suspension on it and it sits about 3/4" lower.
What width wheel and offset would I need?
Old Oct 9, 2008 | 05:55 PM
Socali914's Avatar
Default Re: wheel size help! (ajpturbopittsburgh)
you would need a +25-35 offset but you may rub or probaly will rub against your fenders. im running a 235 40 18 with 25 offset but i have a jdm front end which sticks out 10mm
Old Oct 9, 2008 | 08:28 PM
pd0019's Avatar
what width rim do you plan on running?
245 is wide...thats for like 8"+. if you run an 18x8, you will probably rub in back. i did on my 17x8 + 30. put more camber on and i was fine. i dont know how stiff the hfp setup is, but you may hit the inner fender wall on dips up front.
im with stock struts and comptech springs.
meric0786
Jul 10, 2011 11:16 AM
ilovejdm
25
Feb 28, 2010 05:46 PM
Slick_LudE
Nov 19, 2007 06:49 AM
ridin98civic
Dec 29, 2006 12:12 PM
xTravBx
Mar 10, 2004 08:44 PM
