Calling All Techs!!!!! Tach Will NOT Work
Old Jul 28, 2002 | 10:38 AM
JeffNA's Avatar
Default Calling All Techs!!!!! Tach Will NOT Work
I just finished putting back my head together cause I bent all my valves and some reason, my tach is not working at all. I checked the blue wire on the distributor and it looks fine. My tach was working fine before the valve job but now no luck. Can anyone help me? I have a Field Vtec controller that I use to monitor the RPMs but I would also like my stock tach to work. Everything was fine before but now the tach is dead. Please help.
Old Jul 28, 2002 | 03:08 PM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
Default Re: Calling All Techs!!!!! Tach Will NOT Work (JeffNA)
is the fields working now?? I would try and swap out clusters, maybe the prb is in there.
later
matt
Old Jul 28, 2002 | 03:37 PM
Big Teggie's Avatar
Default Re: Calling All Techs!!!!! Tach Will NOT Work (champITR)
This may sound really dumb. Check the plugs that go to the evap system. Make sure they are all in the right spots, and plugged in. I unplugged one when I was working on my car and forgot to plug it back. The tach didnt work until I plugged it back in.
Old Jul 28, 2002 | 09:28 PM
JeffNA's Avatar
Default Re: Calling All Techs!!!!! Tach Will NOT Work (Big Teggie)
I;ll give those options a try. Anyone else?
Old Jul 28, 2002 | 09:31 PM
Tommy_Gunns's Avatar
Check the wiring with a volt meter. Looks can be decieving.
Old Jul 28, 2002 | 11:03 PM
uNF$@#!'s Avatar
Default Re: Calling All Techs!!!!! Tach Will NOT Work (Tommy_Gunns)
yes, voltmeter is great
helped me with all my electrical problems.
Old Jul 28, 2002 | 11:07 PM
o_Rage_o's Avatar
Default Re: Calling All Techs!!!!! Tach Will NOT Work (Soup ****)
You can also trace its continuity, make sure its not broken.
-Rage
Old Jul 29, 2002 | 07:24 AM
JeffNA's Avatar
Default Re: Calling All Techs!!!!! Tach Will NOT Work (o_Rage_o)
-Rage
I know I start from the distributor with the blue wire. But where do I trace it to?
Old Jul 29, 2002 | 11:24 AM
JeffNA's Avatar
anyone else?
battleREADYb20
Aug 21, 2008 08:53 AM
frostee trooper
Feb 6, 2005 10:58 PM
HuskerHybrid
May 6, 2003 06:24 PM
blacksheep
Feb 10, 2003 09:53 PM
