rims for crx
Old Oct 9, 2008 | 05:00 PM
crxjarred's Avatar
Default rims for crx
what size is to big for crx i dont want rubbing and still want good handling
Old Oct 9, 2008 | 05:15 PM
moonshadowmetallic's Avatar
Default Re: rims for crx (crxjarred)
17's are too big, and 16's are going to give you trouble.
if you run 15's or larger, your going to have to play with tire sizes.
I am assuming you are dropped?
Old Oct 9, 2008 | 07:18 PM
nsxtasy's Avatar
H-T Order of Merit
14" wheels with 185/60-14 tires
15" wheels with 195/50-15 tires
16" wheels with 205/40-16 or 195/45-16 tires
Old Oct 10, 2008 | 02:57 AM
crxjarred's Avatar
Default Re: rims for crx (nsxtasy)
ok thanks and yes im droping but proly just like 2.5inch
Old Oct 12, 2008 | 11:13 AM
TeeBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">14" wheels with 185/60-14 tires
Old Oct 19, 2008 | 04:58 PM
Patty's Avatar
Default Re: rims for crx (TeeBoy)
i run 205/45/16's no problem
Old Nov 1, 2008 | 11:43 AM
08 wdp type s's Avatar
nothing to small ...haha theres a crx rolling around on 20"s in my town
Old Nov 1, 2008 | 04:00 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: rims for crx (Patty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patty &raquo;</TD></TR><TR><TD CLASS="quote">i run 205/45/16's no problem</TD></TR></TABLE>
That size is too big for most CRXs. Note that one exception is the model sold as the del sol VTEC in North America, which I think was sold as the del sol in Japan. But most CRXs came with 175/70-13 or 185/60-14 tires from the factory, and should use 205/40-16 or 195/45-16 tires, which have about the same outer diameter. Using oversized tires like 205/45-16 will make the car's acceleration slower (like getting taller gears), will make the speedometer and odometer inaccurate, and may rub in the wheel wells.
vtec_powah
Apr 18, 2007 09:53 AM
mrchris1979
Feb 4, 2007 09:33 PM
integracura
Jan 26, 2007 11:53 AM
Fat Chick Magnet
Nov 22, 2006 01:13 PM
Mr_Snrub
Jan 22, 2006 06:14 PM
