OBD Connector(NEED HELP SOON)
Old Oct 9, 2008 | 04:51 PM
mafiasutra24's Avatar
Default OBD Connector(NEED HELP SOON)
Hello this might sound stupid but i just bought a 91 Civic Hatchback with the engine light ON . I tried to find the location of the obd1 connector so i could figure out what's wrong with it. So Please let me know where is that connector located at need help soon.
Also the car idles kind of funny i think it might be related with some sensor but i need to check that CEL. How to test and check the CEL (check engine light). the car wont pass over 3000 RPMs.
Old Oct 9, 2008 | 05:14 PM
peter_b16's Avatar
Default Re: OBD Connector(NEED HELP SOON) (mafiasutra24)
check your ecu..the obd0 system has an led light on the ecu..just check the blinks on that and u can figure the code...unless if u convert to obd1, itll be somewhere behind the glove compartment..
Old Oct 9, 2008 | 05:41 PM
Default Re: OBD Connector(NEED HELP SOON) (peter_b16)
okay! if a have an obd1 what do i do? how to use the connectors to figure out the CEL.
Old Oct 9, 2008 | 10:34 PM
flaxx0r's Avatar
its all on the passenger side.. the ecu should blink a red light when the check engine light is on.. its under the carpet..
and unless your motor has been swapd out and converted to obd1 then its a non obd car..
but obd1, there is a blue? plug under the passenger side dash just stick a bent paperclip in it on both sides and jump the wires together
Randyb18
Feb 19, 2015 09:28 PM
EF9Sirjdm14
Mar 16, 2011 08:06 AM
cor4ey
Dec 20, 2008 12:42 PM
Audipwr1
Jun 3, 2003 08:26 AM
