installing new axle
hey guys im installing a new front-passenger side axle on my 90 honda accord ex.
cvc joints busted so yah.
i needed to know the best way to change it. should i drop the front end?
unmount the engine and jack it up?
this is my first time doing this so i could really use some guidance.
woah woah woah, you don't need to do that.... Way too much.
The way i did mine on my 96 Accord (should be same for you) remove axle nut, remove the lower ball joint, (and upper if need be) swing out the steering knuckle, pull out the axle from tranny...
Should be a relatively easy job, but due to rust and years of use, it might be stuck in there pretty good. Some rust are soo bad that that it's practically welded on... Use some PB blaster and time...
ok. yah well i dont know
alright so ill look into that. i dont know what any of those parts are, but google never failed me automotively yet
thanks man.
any other opinions just to verify before my car falls of its frame?
thanks man.any other opinions just to verify before my car falls of its frame?
https://honda-tech.com/zerothread?id=382416 here is a DIY link. That's how its done. Follow that k?
JDMTEG98
Sep 13, 2007 03:59 PM
Pochtecatl
Jul 11, 2004 11:43 AM
