Fly wheel bolts?
well, after being told they were not reusable, i went ahead and shelled out 6 bucks a bolt
whats the torque specs on those?
and transmission housing?
last question...i broke the bracket from the trans to the motor...the new one is 5 days away through the dealer...
how necessary is this bracket, and will i survive a few days without it? i wont be beating on the car, as im going to properly break in the clutch (any tips on this procedure will be appreciated BTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ElCoronaCartel »</TD></TR><TR><TD CLASS="quote">well, after being told they were not reusable, i went ahead and shelled out 6 bucks a bolt
how necessary is this bracket, and will i survive a few days without it? i wont be beating on the car, as im going to properly break in the clutch (any tips on this procedure will be appreciated BTW)</TD></TR></TABLE>
You didn't say which motor
If you're talking about the flywheel cover on the bottom next to the oil pan, then yes you can go without it. If you have just a plate and the brackets, you'll make it 5 days.
Can't help you on torques. Somewhere around 72ft*lbs for the flywheel, 65 f*lbs for the big bolts (17mm+19mm socket), 45ft*lbs for the 14mm heads
You can reuuse the flywheel bolts if they are in good shape, use thread lock though.
75-80 for flywheel bolts. I've never used Locktite, but have seen many come loose on other builds/clutch jobs.
Make sure flywheel and crank are clean before install.
hondaaccordlx23
Jul 5, 2017 12:14 AM
socialistic
11
Apr 13, 2013 07:25 PM
mikey8422
Feb 18, 2009 03:54 AM
