Brake Assembly Bracket Bolts Torque Spec
I have a Honda Accord 1991 LX 2.2 L (F22A6 ) - I am looking for torque spec for bracket bolts ( Short Bolts ). I have found one source claims is 80 ft-lbs another 36 ft-lbs? Wondering which one is correct?
Re: Brake Assembly Bracket Bolts Torque Spec
Which "short" ones are you talking about.....the ones that hold the bracket to the knuckle or the ones holding the caliper to the bracket?
The 80 is the caliper bracket to the knuckle and the 36 are the caliper to the caliper bracket. You really want those caliper bracket to the knuckle tight or they could back out and you could die while driving. Don't play around with those. Get those tight af.
Welding / Fabrication
16
12-05-2007 12:04 PM
90civichbsi
08-09-2006 12:26 PM
