b16 n/a build
Old Oct 9, 2008 | 10:07 AM
pat91hb's Avatar
Default b16 n/a build
hey...i got a b16....has 97 type r cams in it....i was wondering what kind of h/c pistons/rods you guys could recommend to me as well as whether i should keep those cams i or not (bought it like that)
Old Oct 9, 2008 | 07:17 PM
pat91hb's Avatar
Default Re: b16 n/a build (pat91hb)
bump
Old Oct 9, 2008 | 07:51 PM
EF_EJB16A's Avatar
you can get inexpensive forged piston and rod combos on ebay. i was get ctr pistons
Old Oct 10, 2008 | 08:44 AM
00b20vtecoupe's Avatar
Default Re: b16 n/a build (EF_EJB16A)
ctr pistons r garbage but if i would rec. pistons ide say cp with eagle rods but i would rec. another thing it would be to ditch the block and do either a gsr block or sumthin like a b20 for b20 vtec all motor b16 is kinda weak. or another stock piston would be the jdm b16 pistons a lil better than stock and they r cheap.
Old Oct 10, 2008 | 08:46 AM
00Red_SiR's Avatar
All Motor Mentor
First question, is why do you want to change the pistons and rods. Second is what are you attempting to do with the car? plans? goals? intended usage?
Old Oct 10, 2008 | 09:34 AM
pat91hb's Avatar
Default Re: b16 n/a build (00Red_SiR)
i want to change the pistons because i want higher compression (also thinking of a 50 shot wayyyy down the road) and i want aftermarket pistons also because im going to drag it. and i mean since id be changing the pistons its retarded not to upgrade the rods no? goals....low/mid 12's....it runs a 13.9 now....thanks for the input so far guys
Old Oct 10, 2008 | 09:58 AM
LUIlui77's Avatar
ur plans are good, except 1 detail. High compression on the shot may not be the route ur wanting to take. U could end blowing gasket/rod. I got a b16 in my 88Si. Ive got plans for a Mid 12s daily driver. From I read/hear/know (honda-tuning/best motoring/vtec club) an all motor setup setup is best achieved with compression above normal, low would b a route for turbo/nos(imo)
Old Oct 10, 2008 | 10:39 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pat91hb &raquo;</TD></TR><TR><TD CLASS="quote">i want to change the pistons because i want higher compression (also thinking of a 50 shot wayyyy down the road) and i want aftermarket pistons also because im going to drag it. and i mean since id be changing the pistons its retarded not to upgrade the rods no? goals....low/mid 12's....it runs a 13.9 now....thanks for the input so far guys </TD></TR></TABLE>
You can increase the compression by running JDM b16a pistons (p30) and switching to a GSR head with flat faced valves, 2 layer head gasket etc but you'd be better off using a larger block for more power.
The stock rods are plenty strong in the b16a and a 50 shot of N2O is negligible and wouldn't really require upgrading anything to use it, just proper tuning.
Old Oct 10, 2008 | 12:09 PM
pat91hb's Avatar
thanks alot dude....researched this a bit and sounds pretty cheap....
thatguamanionkid
Mar 8, 2009 10:52 AM
streetracerof06
Feb 2, 2006 05:08 PM
vtecn8ive
Oct 4, 2005 06:40 PM
Dan GSR
Sep 19, 2003 08:07 AM
TypeR0wnz
Feb 15, 2003 03:46 AM
