HELP!!!! 2000 HONDA CIVIC SI ; ENGINE LIGHT FLASHING; CHOKING
Old Oct 9, 2008 | 08:23 AM
jsb996's Avatar
Default HELP!!!! 2000 HONDA CIVIC SI ; ENGINE LIGHT FLASHING; CHOKING
My SI's engine light started flashing yesterday while I was driving. When my car is at a stop/or idle, the engine doesn't die but it's like it's choking. Does anyone know what's wrong or how to fix my car? Please help....
Old Oct 9, 2008 | 08:27 AM
B16AGUY's Avatar
Default Re: HELP!!!! 2000 HONDA CIVIC SI ; ENGINE LIGHT FLASHING; CHOKING (jsb996)
Could be a few things.
Take the car to autozone and have them scan for which check engine code the car is throwing. Then post the code here and people will have a better idea what you need to do.
Old Oct 9, 2008 | 09:08 AM
Former User's Avatar
You could also pull the CEL code at home using the jumper wire method:
https://honda-tech.com/zerothread/1901557
When the CEL flashes, it is warning you that the engine is misfiring at a level that may damage the catalytic converter. Therefore, stop driving the car until you fix the problem.
Old Oct 9, 2008 | 09:56 AM
robfrmny21's Avatar
if your check engine like is flashing then it means you have a 50% or more misfire in one or more of the cyl's
Old Oct 9, 2008 | 10:03 AM
gsrhatch2356's Avatar
the flashing light does mean catalyst damage, but dosent have to be a misfire. I have seen this on injectors that had a slight leak and just ran to rich but was still able to get off a combustion cycle.
Old Oct 9, 2008 | 08:29 PM
jsb996's Avatar
Default Re: HELP!!!! 2000 HONDA CIVIC SI ; ENGINE LIGHT FLASHING; CHOKING (gsrhatch2356)
New sparks plug was the solution guys!! Thanks for the help.
pindented
Jul 11, 2013 11:07 AM
Pabs626
Jul 2, 2008 09:06 AM
roller
Jun 13, 2004 11:57 PM
staticchmbr
Apr 14, 2004 04:54 AM
eg686
Apr 18, 2003 01:01 PM
