All Motor Question... Skunk 2 vs JG EldeBrock Victor X
I wanted to know on the which one is better in overall and power production in All Motor form... The Skunk 2 or the Victor X ... please post your opinoin and your findings ... thank you
ok ok I apologize... heres my build:
BLOCK:
-Closed Deck Sleeved B18C
-85mm RS Machine Pistons
-11.75:1 compression
-Brian Crower Rods
-Micro-polished/Knife Edge crank
Head:
-B18C
-Ported and Polished
-3 Angle Valve JOB
-Skunk 2 Valves STD. compression
-Skunk 2 Springs
-Skunk 2 Ti retainers
-Skunk 2 Pro 2's
planning on running 370cc injectors, 190lph walbro ( already B&M reg.), and run a 68mm throttle body. Hoping to tach this thing out to 9500rpm w/ itr 4.7 trans...
Modified by RippSpeed at 11:26 AM 10/9/2008
BLOCK:
-Brian Crower Rods
Head:
-B18C
-3 Angle Valve JOB
-Skunk 2 Springs
-Skunk 2 Pro 2's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FST GSR 1 »</TD></TR><TR><TD CLASS="quote">What is the real compression of the motor, was it actually CC'd? Do you plan to use any spray in the future or keep this NA?</TD></TR></TABLE>
No it never did ... no plans of spray at all ... Just Striaght N/A
LMAO, I run PRO 2's in a 11:1 ,1.8 with a 3" collector header and a big *** VX and put out 210/140 on motor. Car was built for spray. It should put out well over 325 on the bottle with an *** load of torque.
riceboyEFsi
Apr 7, 2003 03:32 PM
