1995 Accord starts when dry, won't start when raining or foggy.
Old Oct 9, 2008 | 07:05 AM
fortyfacemohwhat's Avatar
Default 1995 Accord starts when dry, won't start when raining or foggy.
New starter, battery, and alternator is good. What could this be? I also replaced the distributor cap last year when I had the same problem, and it seemed to fix the problem, but only temporarily.
Old Oct 9, 2008 | 10:56 AM
dgkrzy's Avatar
Default Re: 1995 Accord starts when dry, won't start when raining or foggy. (fortyfacemohwhat)
I had a hairline crack in a distributor cap cause the same problem. The car would start but run really rough & misfire. I couldn't even see the crack until I took the cap off to replace it. You may want to check coil / plug wires closely for this. You may also want to look for poor or corroded terminations on starter.
Old Oct 17, 2008 | 05:40 PM
P_Adams's Avatar
Did that last post put you in the correct direction?
It is true, both the distributor cap and the High Voltage Ignition wires can get pourous over time; and absorb moisture during damp / rainy mornings. thus keeping the car from starting.
This can be easily tested (at this point) with nothing more than a spritz bottle.
With a fully warmed up engine, start spraying the wires first - working towards the cap.
If you've a problem, the engine will start missfiring and possibly stall.
The heat from that pre-warmed engine will dry the wires off (however), so you should be good (after sorts) to go to the local Death Zone auto parts store for your new Cap, Rotor and Wire Set.
13BT
Jul 26, 2005 06:10 AM
jdmlude_dude
May 2, 2005 09:39 PM
lilgreenlude93
Apr 7, 2004 10:20 PM
aktc167
Apr 28, 2003 11:46 AM
hoysum_dimsum
Feb 15, 2003 05:39 PM
