Changing oil pan gasket. Where should hondabond be applied? Is Hondabond necessary?
Old Oct 9, 2008 | 01:06 AM
4drint3gr4's Avatar
Default Changing oil pan gasket. Where should hondabond be applied? Is Hondabond necessary?
Where should the hondabond be applied? I'm not sure where it should be put on, if anyone has done this before can ya tell me where ya applied the hondabond. I'm not sure if I should placed it all around the pan or just some places. And did anybody get away without using and hondabond? any leaks after? Just curious.
Old Oct 9, 2008 | 04:29 AM
blueDA9's Avatar
Default Re: Changing oil pan gasket. Where should hondabond be applied? Is Hondabond necessary? (4drint3gr
i'll tell you whats more important than the hondabond first. make sure the gasket mating surfaces are CLEAN! then put hondabond on the gasket and then put the gasket on the oil pan, then bolt her back up.
Old Oct 9, 2008 | 06:27 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueDA9 &raquo;</TD></TR><TR><TD CLASS="quote">i'll tell you whats more important than the hondabond first. make sure the gasket mating surfaces are CLEAN! then put hondabond on the gasket and then put the gasket on the oil pan, then bolt her back up.</TD></TR></TABLE>
X2
Spray some type of cleaner to get the oil off. Put hondabond all around.
Old Oct 9, 2008 | 06:58 AM
92DAIntegraXSI's Avatar
you can get away without using hondabond. like others stated make sure the surfaces are clean of grease and oil theres no washers left on the two studs closest to the flywheel side and bolt it back up. and you dont need to use your ******* hand to tighten it. ive seen many people who over tighten the little 10mills and mushroom the gasket
Old Oct 9, 2008 | 02:03 PM
4drint3gr4's Avatar
Thanks for the help!
Old Oct 9, 2008 | 07:07 PM
NUISANCE's Avatar
Brake cleaner on a rag works well for getting the oil off. Make sure all of the old gasket is off too.
imadigitalgod
Apr 8, 2010 09:48 AM
4DRmafia
Feb 6, 2007 12:04 AM
crumb
Apr 24, 2006 09:51 AM
DualCamDan
Jul 26, 2005 04:19 AM
James
May 11, 2004 01:38 PM
