D15 vs D16 Vitara build. Yes I searched.
Old Oct 8, 2008 | 05:25 PM
Attoir's Avatar
Default D15 vs D16 Vitara build. Yes I searched.
I know what the differences are in the motors. Crank size and stroke, primarily.
My question is, in a quest for 400hp (or as close as i can get) vitara build, will I hit a wall with the D15?
(we'll say we're talking jdm d15b vs d16z6)
Old Oct 8, 2008 | 05:45 PM
tony413's Avatar
Default Re: D15 vs D16 Vitara build. Yes I searched. (Attoir)
d-series.org
turbod16.com
you will find your answer there
Old Oct 8, 2008 | 05:55 PM
Schister66's Avatar
Man U FTW
The problem here isn't the pistons, its the rods. The stock D rods aren't good for more than about 220-240whp more often than not. Since the D15 has a different stroke than the desired D's, i dont think rods are available (at least as cheaply) as they are for the D16's
Old Oct 8, 2008 | 07:01 PM
SovXietday's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">The problem here isn't the pistons, its the rods. The stock D rods aren't good for more than about 220-240whp more often than not. Since the D15 has a different stroke than the desired D's, i dont think rods are available (at least as cheaply) as they are for the D16's</TD></TR></TABLE>
FJT has D15 rods designed for the average Vitara build.
I have yet to see a D15 go over 400 yet, infact, I haven't seen one do over 300 yet. Not to say they can't, they're just that uncommon.
Old Nov 10, 2008 | 05:04 PM
1wiperDude's Avatar
Honestly, this is ur solution IMO:
http://fjdistributors.com/prod...d=285
everyone raves about them. Just my .02
Good Luck with the build man.
Old Nov 10, 2008 | 07:05 PM
z6hatchboy's Avatar
I havnt seen many d15's reach that either, id say the z6 easy. I did a vitara z6 build check my sig, and message me if you need any help
Old Nov 10, 2008 | 07:53 PM
HiProfile's Avatar
Default Re: (z6hatchboy)
Lets look at it another way: I've never seen a D16 fail due to the less optimal rod/stroke ratio. Its marginal at best between the two, and you need all the displacement you can get (unless you're bisimoto).
The other issue is the D15 with 'normal' rods will yeild a much lower than normal CR with vitaras, which is already poor with D16's. You can go with the fjt rods, but for the same price you can get his D16 rods that give you a better R/S ratio in addition to bringing the CR up a tad. One more issue is the head & tranny. W/o lots of added parts in the head or better gearing, the higher theoretical RPM's are next to useless.
D16 &gt; D15 &gt; D14 (EDM)
Old Nov 10, 2008 | 09:25 PM
HuntsTURB0civic's Avatar
brian crower is the only company i know of that makes rods for the d15...
Old Dec 25, 2008 | 10:17 AM
slywfbpsi's Avatar
http://fjdistributors.com/product_in...roducts_id=271
Kendall
14
Mar 1, 2023 07:16 PM
nerdsports
Jul 21, 2003 05:15 PM
turbohf
May 25, 2002 08:45 PM
