strange tachometer problem
Old Oct 8, 2008 | 04:49 PM
92integracer's Avatar
Default strange tachometer problem
When i am at a stop my tach will quickly drop to 0 and then jump back up to idle again, but the engine isn't stumbling and I am not having a noticable idle problem. I don't have this problem when driving. I am not getting any codes thrown either. Is there something wrong with my distributor or is the problem coming from somewhere else?
Old Oct 8, 2008 | 05:42 PM
higgunscrx's Avatar
could be the alternator is on its way out, i noticed this happened to me just before my alternator took a ****.
i think it has something to do with the voltage regulator. try starting the car and put a multi meter on the battery and see if the voltage jumps. if it does thats your prob.
Old Oct 8, 2008 | 06:03 PM
would the voltage jump just on start up or while running? You don't even use your alternator on start up right?
Old Oct 8, 2008 | 09:19 PM
EKDee's Avatar
kind of hard to tell from what you've described but I had a similar problem when the tach would bounce up and down during idle and low rpms and turned out that my ICM was going out.
It lasted about a month doing that until it just went completely out and I had to buy a new one.
Lord Asbaat
Honda Civic (2001 - 2005)
Aug 11, 2017 05:19 AM
stocker2shocker91
Mar 22, 2008 03:52 PM
tweekerz
Aug 12, 2007 08:06 PM
ballerchild
May 21, 2007 03:52 PM
ic89
13
Oct 23, 2006 09:54 PM
