1990 EX...red battery light stays on
Recently replaced alternator and battery. Charging system checks out just fine, 13.5 + volts under heavy load. All fuses and relays are good and literally everything works perfectly..except the damn red battery light stays on ALL of the time. Like I said everything works well but the battery light is a new symptom and I am scratching my watch at this point. Any help is greatly appreciated.
haywyre
haywyre
Alternator is definitely good.
That usually knocks out the culprits with it haha. Alternator being the main one.
I'm also guessing along with that the belt is tightened correctly and does not slip up?
I don't have any other suggestions, those are the only causes I've seen in relationship to the battery light. It should not need to be reset (like the SRS light) so that's not the issue, and if the alternator and battery are both good and functional then obviously it's not that.
Hopefully someone else can step in to help you. Sorry I couldn't be more useful.
bleedblue94
May 20, 2006 07:57 PM
Alexnaderkeith
Sep 10, 2003 08:32 AM
