stock b20vtec what psi on B&M FuelPressureRegulator/ FuelPressureGage
Old Oct 8, 2008 | 11:26 AM
b20vtech's Avatar
Default stock b20vtec what psi on B&M FuelPressureRegulator/ FuelPressureGage
need a little help from u guys, motor is runnning on the lean side , i would like to know how much psi should i run on the fpr/fpg to help this motor a little bit.
here's the motor spec:
b16vtec head
stock gsr cams
jg manifold w/ 68 tb
oem type r header
b20b block untouched
stock injectors
Old Oct 8, 2008 | 01:12 PM
fronomo's Avatar
around 46-52 at idle i believe. thats what i set mine to, works great no complaints
Old Oct 8, 2008 | 08:54 PM
b20vtech's Avatar
Default Re: (fronomo)
is this with the little vacuum thing attached or removed from the fpr?
Old Oct 8, 2008 | 09:19 PM
onepoint6i's Avatar
Default Re: (b20vtech)
removed, always adjust it with the vacuum hose removed.
Old Oct 9, 2008 | 07:55 AM
b20vtech's Avatar
Default Re: (onepoint6i)
gotcha thanks
Old Oct 9, 2008 | 09:13 AM
civiconfire's Avatar
it you tune it it should be like 45. but you can pretty much set it wherever and the tuner should adjust for it, or set it where he wants it.
Razr2
13
Nov 6, 2007 04:41 PM
vtec25
Jun 24, 2007 12:31 AM
spooned out
Jun 16, 2004 04:10 AM
hi mom
May 11, 2004 11:24 AM
lucas569
Sep 19, 2001 04:44 PM
