What should my FPR be set to? I think I'm running rich - 1999 Civic Si
I have a 1999 Civic Si, basically stock b16 with just boltons. My car had a B&M FPR, but I don't know what to set it to. The previous owner said it may be running a little bit rich, and it's been like that for over a year now, and I haven't messed with it.
So yea, do I just start my car up and look at the guage? What should it read? If it's to high or too low should i adjust it and how? Can It have caused my engine any harm from running to rich for a long time? Also can you seriously mess up your motor if you set it incorrectly?
Sorry for the *** load of question, all help appreciated.
Re: What should my FPR be set to? I think I'm running rich - 1999 Civic Si (Razr2)
Run a stock FPR. If you want to mess with fuel, have it dyno tuned, which sounds like you probably don't have enough modifications to need.
i beleive it should be about 37psi, at idle with vacuum, without vacuum 45-47, and yes u can damage the motor but if your only 3-4 psi off ur probably not going to hurt anything exept performance.
Darth ModerVader
Re: What should my FPR be set to? I think I'm running rich - 1999 Civic Si (boostedh22lude1)
The Helm states that the pressure should be between 40-47 psi with the vacuum hose disconnected.
ull actually increase performance running rich, but will be increasing emissions
Darth ModerVader
Re: What should my FPR be set to? I think I'm running rich - 1999 Civic Si (Magik123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magik123 »</TD></TR><TR><TD CLASS="quote">ull actually increase performance running rich</TD></TR></TABLE>
Not necessarily.
Not necessarily.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magik123 »</TD></TR><TR><TD CLASS="quote">you gotta be running really really rich to hurt ur motor</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magik123 »</TD></TR><TR><TD CLASS="quote">ull actually increase performance running rich, but will be increasing emissions </TD></TR></TABLE>
Yeah, people dyno tune just for fun
Keep those comments to yourself.
Re: What should my FPR be set to? I think I'm running rich - 1999 Civic Si (gibsanez)
okay so to check it I just start my motor, let it warm up, then it should read the number? How do I adjust it?
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razr2 »</TD></TR><TR><TD CLASS="quote">okay so to check it I just start my motor, let it warm up, then it should read the number? How do I adjust it?</TD></TR></TABLE>
Once the engine is warm, pull the vacuum hose from the regulator, then check the reading. You adjust the B&M by loosening the stop nut, turning the screw, then tightening the stop nut again once you're finished.
ok u explain how u damage ur motor running a lil rich then smart guy besides fouling plugs.... u dyno tune so u dont go lean knock till u melt a piston. Let me see ur emissions liscense next time u wanna make a comment
to the O.P i would suggest like he said if u want it perfect to go to someone who tunes cars to set it up for best performance. If you do it urself it prob. wont be perfect but a little on the rich side is better than alittle on the lean side so u know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magik123 »</TD></TR><TR><TD CLASS="quote">ok u explain how u damage ur motor running a lil rich then smart guy besides fouling plugs.... u dyno tune so u dont go lean knock till u melt a piston. Let me see ur emissions liscense next time u wanna make a comment</TD></TR></TABLE>
well you can also kill your rings by running too rich but im sure you knew that mr emissions
Re: What should my FPR be set to? I think I'm running rich - 1999 Civic Si (electron_si)
yes because running alil rich is gonna kill ur rings i said that if ur not running pig rich <U></U> do u really think honda honda gave u the best possible fuel supply you can have? or the best performance with the best mpg they could achieve as its an economy car (more than likely the latter IMO) ur acting like im saying unplug ur FPR and drive around town ull get the best performance ever
99TurboFerio
04-07-2005 04:37 PM
