Golden Eagle VTEC fitting VS Russell Fitting
Old Oct 8, 2008 | 08:58 AM
vacantskies88's Avatar
Default Golden Eagle VTEC fitting VS Russell Fitting
Locally I can get better prices from a shop for the Russell/Edelbrock -6AN to 1/8"NPT fittings than I can for the Golden Eagle Cylinder Head to -6AN fittings
Are these essentially the same part?
Russell #660450/660451/660453
Golden Eagle #GVCHeadAN6
Thanks
Old Oct 8, 2008 | 10:30 AM
DonF's Avatar
Default Re: Golden Eagle VTEC fitting VS Russell Fitting (vacantskies88)
NO.
Old Oct 8, 2008 | 10:36 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Golden Eagle VTEC fitting VS Russell Fitting (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">NO.</TD></TR></TABLE>
X2
Damn, look at your pics and ask that question again.
Old Oct 8, 2008 | 11:48 AM
pgpbubble's Avatar
Its -6an to 3/8NPT. not 1/8 NPT
Old Oct 8, 2008 | 11:53 AM
Furyof4's Avatar
Default Re: Golden Eagle VTEC fitting VS Russell Fitting (pgpbubble)
Actually, Honda uses BSPT not NPT threads.
Old Oct 8, 2008 | 12:20 PM
DonF's Avatar
Default Re: Golden Eagle VTEC fitting VS Russell Fitting (Furyof4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 &raquo;</TD></TR><TR><TD CLASS="quote">Actually, Honda uses BSPT not NPT threads.</TD></TR></TABLE>
Old Oct 8, 2008 | 02:13 PM
pgpbubble's Avatar
Correct, But the thread difference is near to nothing in difference, It barely barely distorts thread sizes. Ive always used NPT.
Old Oct 8, 2008 | 02:46 PM
DonF's Avatar
So you can get 1/8 pipe fitting to work? How much teflon tape? 2 rolls?
Old Oct 8, 2008 | 05:27 PM
Phil M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">So you can get 1/8 pipe fitting to work? How much teflon tape? 2 rolls?</TD></TR></TABLE>
Pffft, you don't know what you're talking about. EVERYONE knows that teflon tape has the same tensile strength as steel and or high grade aluminum.
ROLL IT HIGH LET IT FLY!!
Old Oct 8, 2008 | 05:56 PM
lude98SH's Avatar
Default Re: Golden Eagle VTEC fitting VS Russell Fitting (Phil M)
1/8" - 28 BSPT
1/8" - 27 NPT
Could you just retap it ? Its so close.
Old Oct 28, 2008 | 06:58 PM
93Civic_hb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil M &raquo;</TD></TR><TR><TD CLASS="quote">
ha. I would like to see the tensile strength of this space-age teflon tape you are talking. 32k psi. NA...
Old Oct 29, 2008 | 08:00 AM
Golden Eagle's Avatar
not the same and thats just the head fitting you still need the rest of the kit
Old Oct 29, 2008 | 10:02 AM
FST GSR 1's Avatar
You can't re-tap because they are so close.
It's common to see a BSPT(R) and BSPP(G) interchanged. It's also common to see G/R's into a NPT because the MD and PD are smaller on G/R's and "can" work in a NPT hole. However, not vice versa.
ON EDIT: For argument sake the MD on a 3/8NPT is .675, the MD on a R/G 3/8 is .655 or 16.662mm. Not to mention form angle of 55 vs. 60. Do the math.
Modified by FST GSR 1 at 11:22 AM 10/29/2008
Old Oct 30, 2008 | 02:14 PM
lude98SH's Avatar
Default Re: (FST GSR 1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FST GSR 1 &raquo;</TD></TR><TR><TD CLASS="quote">You can't re-tap because they are so close.
Why would them being close not work ? I mean the tap is different and its an aluminum head that is extremely easy to do.
Old Oct 30, 2008 | 02:16 PM
Default Re: (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">
Why would them being close not work ? I mean the tap is different and its an aluminum head that is extremely easy to do. </TD></TR></TABLE> because there the same size different thread
Old Oct 30, 2008 | 02:25 PM
lude98SH's Avatar
Default Re: (Golden Eagle)
gotcha
Golden Eagle
30
Mar 17, 2008 03:36 PM
allmotor2.1
Oct 18, 2007 02:25 PM
JDMCRX
Jun 28, 2007 03:02 PM
high boosted rex
Feb 20, 2006 03:24 AM
TURBO-TEG
Apr 20, 2004 09:10 AM
