DIY rewrapping door panel inserts
need some help
anyone know how to do this on integra or someone have a write up... ive searched found quite of few pics of civic and a couple of tegs.... attempted to do it myself few days ago ...
1 can of spray adhesive
exacto knife
red tweed fabric
1.I removed the door panels
2.removed the inserts
3.removed stock cloth inserts
4.cut fabric to match size of stock fabric
5. masked off rest of door so glue wouldn't get all over the place
6. sprayed light coat of adhesive
here is the problem when i lay the fabric and try and wrap it im left with bunches of fabric folds around the corners and the edges dont quite tuck right... is there some special way im supposed to lay fabric out to get it to stretch right so its not bunched up...ive looked at some of the pics on
https://honda-tech.com/zerothread?id=2383997
https://honda-tech.com/zerothread?id=1825612
and it looks so clean... if anyone has wrapped inserts before do you have any advice on how to do it better ... im gonna reattempt it tonight and use rubber cement and try and tuck the corners better...any helpful input would be nice thanks.
i wrapped my old ls door panels with black suede...
Start working from the inside out towards the edges...once you get to the edges, use a squeggy or blade to gentle spread it out, stretch it, and fold it in the crevice where the door panel insert ends...
It worked like a charm for me, and it came out almost perfect..
Good luck and post pics of the work
attempted it again last night... I bought different fabric.. is a lil stretchy so i was able to wrap arounds corners very well....used the same spray glue and just neatly trimmed the edges once the glue stuck will try and take pics tomoro when I have some time.
ZzZCivicZzZ
Welding / Fabrication
Apr 15, 2010 04:59 PM
specoperformance
Sep 15, 2008 03:26 PM
ef93si
Aug 25, 2006 08:33 PM
