90 si with obd2 b20 fuel problems
Old Oct 8, 2008 | 06:24 AM
toda_ef9's Avatar
Default 90 si with obd2 b20 fuel problems
i installed a walbro 255 fuel pump and an adjustable fuel pressure regulator. I know now that the resistor box cannot be used with obd2 injectors or plugs which i have... would the resistor box be what is making my car idle and run rough?
Old Oct 8, 2008 | 11:53 AM
Speed PHreak's Avatar
Default Re: 90 si with obd2 b20 fuel problems (toda_ef9)
Did you install a gauge when you put your pump/reg in? You'll need to adj your fuel pressure back to stock settings or at least what the ECU was tuned for if it's chipped/aftermarket.
Also running OBD-2 injectors WITH a resistor box will cause all sorts of issues. Bypass the resistor box or get OBD-0 injectors.
Old Oct 8, 2008 | 01:38 PM
toda_ef9's Avatar
Default Re: 90 si with obd2 b20 fuel problems (Speed PHreak)
i bought the gauge for the reg. but its not installed because im having trouble finding an adapter so the gauge will fit ontop of the fuel filter. im running a stock ls ecu, how would i find the stock level.
MantisX
Engine Management and Tuning
May 20, 2010 04:24 PM
MantisX
May 30, 2008 11:53 AM
TurboTD05civic
Jan 28, 2008 06:52 PM
cashshoes
Feb 25, 2007 09:09 PM
