Question on swap, newbie guy, perhaps a cashflow comming in...
Old Jul 28, 2002 | 01:25 AM
Ideal's Avatar
Default Question on swap, newbie guy, perhaps a cashflow comming in...
I might be getting a good amount of cash flow soon, so i have a few questions...
1)I would like to do a swap for a h22a, now are there different models, like h22a1/2 or something? Also, i see on some pics that theres is this thing that says DOHC, what exactly is it? and Can it come with the h22a?
2)My 93ex accord is automatic, when im done with the swap, i want it to be a stick, i bet i will have some problems, probably alot, but, after i do this, will i lose anything, like maybe my speedometer wont be accurate, or my rpms, and because its being changed so drastically, will everything shift right?
3)I Keep hearing from a bunch of friends that when you do a whole swap, that the car just isnt good, something is missing, it doesnt do something like its supposed to, has anyone done a complete swap to a stick with no problems, or am i likely to have problems that will last me a lifetime?
Thanks guys, sorry, im a complete newbie, oyea what exactly is DOHC?
thanks again.
Old Jul 28, 2002 | 02:51 AM
2.2dc2's Avatar
Default Re: Question on swap, newbie guy, perhaps a cashflow comming in... (Ideal)
1.)
H22A4 Honda Prelude Vtec 97-01
H22A1 Honda Prelude VTEC 1994-1996
H23A4 Honda Type SirT/Accord Wagon (JDM)
F20B- Accord Euro Type R
sorry if not accurate...dont know much cept the one i want...hahaha h22a4
2.) shouldnt be any problems. shifting wont be a problem it'd be rediculous to do the swap if any problems occured with the synchros
3.) they just dont want you to smoke them!! haha none that i've heard of in a 4th gen.
Old Jul 28, 2002 | 06:58 AM
Gennady's Avatar
New User
DOHC = Double Over Head Cam.
All H22's are DOHC. Your engine is SOHC. Lets see if you can figure out what SOHC means...
In addition to the ones previously listed, there is an H22A7 and a JDM H22A.
If your friends are as knowledgable as you, you have nothing to worry about.
Old Jul 28, 2002 | 09:20 AM
Ideal's Avatar
Default Re: Question on swap, newbie guy, perhaps a cashflow comming in... (accordonc2s)
1.)
So what is a better swtich for a 4th gen, i want speed, and lots of it, and something reliable. Is a f20b faster than any h22/h23?
Also from doing so many changes, basically the swap and making it a stick, how much will it run for completely everything?
I dont have the tools to do it myself, so im not sure if I might have a shop do it, and be there when they have it installed
... unless somone knows/lives anyone in santa clarita/valencia/canyon country...l.a... with a shop.
Old Jul 28, 2002 | 09:40 AM
Nick M's Avatar
forget the F20b
You want an H22a1 or the JDM H22a, if u can spring for it, you can get an H22a4 or the JDM H22a Type S version and then do an OBD1 conversion but it depends on your budget of course, all 97+ H22a's are open deck as well, something to consider.
Old Jul 28, 2002 | 09:48 AM
Ideal's Avatar
Default Re: Question on swap, newbie guy, perhaps a cashflow comming in... (HondaSport)
forget the F20b
What is faster, the h22a4 of the JDM h22a Type S, why do a OBD1 conversion? I know OBD2 exists, will i lose performance? and what does having it OPEN DECK mean?
Sorry for all the questions...
-ideal
Old Jul 28, 2002 | 09:30 PM
Ideal's Avatar
anybody? im surprised its taking this long, heh.
-ideal
Old Jul 29, 2002 | 05:10 AM
jweller's Avatar
OBD2 is much more restrictive as to what you can do as opposed to OBD1. If you can legally do it, stay OBD1.
Open deck means that you have floating cylinder sleeves. the water passages are open at the top of the block. you can see it in this pic. ignore the stuff about a knock sensor, and yes, I know its a b-series but the concept is the same. look right around the pistons, and you will see that there is an open space between the piston sleeve and the rest of the bock.
on a closed deck block that would be filled in. domestic V8s for example use a closed deck block.
edit:
we seem to have a red x, heres the link
http://www.c-speedracing.com/howto/lsvtec/pics/noknocksensorb18a.jpg
[Modified by jweller, 2:11 PM 7/29/2002]
[Modified by jweller, 2:12 PM 7/29/2002]
Old Jul 29, 2002 | 05:36 AM
Gennady's Avatar
New User
JDM H22A Type S is 220ps, and OBDII. OBD conversion can get pricey...just ask Dave.
Old Jul 29, 2002 | 08:55 AM
Razor's Avatar
Default Re: Question on swap, newbie guy, perhaps a cashflow comming in... (Wont be beat)
try to get the h23a from japan, the 2.3 dohc vtec motor.
Old Jul 29, 2002 | 10:34 AM
Ideal's Avatar
Default Re: Question on swap, newbie guy, perhaps a cashflow comming in... (Razor)
how much does a obd1 conversion run?
is getting the h23a with a dohc vtec motor faster than the 220hp posted above?^^
-ideal
Old Jul 29, 2002 | 11:33 AM
Gennady's Avatar
New User
Dude, its not ******* rocket science! 220>200 right?
Old Jul 29, 2002 | 12:28 PM
Ideal's Avatar
try to get the h23a from japan, the 2.3 dohc vtec motor. = that is 220 or 200?
Old Jul 29, 2002 | 01:42 PM
ForcedAccord's Avatar
Texas B*tch!
The type-s is going to have a higher compression, which is how it's producing more power than the regular h22's. Nothing THAT special.
Old Jul 29, 2002 | 05:19 PM
Spooch69's Avatar
I always thought dohc was Dual over head cams?
Old Jul 29, 2002 | 05:56 PM
Ahab's Avatar
Default Re: Question on swap, newbie guy, perhaps a cashflow comming in... (Spooch69)
It does.
Old Jul 29, 2002 | 06:24 PM
l0p3z's Avatar
that's funnny... me too... hmm?? but then again dual and double practically means the same thing anyways
Old Jul 29, 2002 | 06:30 PM
Gennady's Avatar
New User
Same shizZLe mAH NiZzlE
Old Jul 29, 2002 | 11:08 PM
2.2dc2's Avatar
i actually found a h23a4 from my friends distributor, and boy is that bitch clean. no tranny, just long block. I am waiting for a price, and will pick that up until i have enough for a h22a tranny and a act stage 3 clutch, and lsd. Can't wait!! 220bhp
Joseh22si
May 21, 2016 07:35 AM
SkatingStoner95
Classic Hondas
Jul 17, 2012 01:39 AM
Civiclized
Nov 19, 2005 04:18 AM
smuggy
Jan 9, 2003 01:10 PM
