timing belt issue
Old Oct 7, 2008 | 10:20 PM
jimmy o.'s Avatar
Default timing belt issue
Well after i got my 94 running i noticed the belt is trying to move off the pulleys i dont know why maybe the tensoner is lose i dunno anyone ever had this problem someone told me it had something to do with my head being machined i dont know all i know the only thing keepng it on is the timing cover. Any help would be appreciated thanks
Old Oct 8, 2008 | 09:06 AM
jimmy o.'s Avatar
bump
Old Oct 8, 2008 | 09:35 AM
oemcivic0888's Avatar
try loseing the tenstior then retigting it.
Old Oct 8, 2008 | 10:33 AM
jimmy o.'s Avatar
is there a way to get to it without taking everything back apart
Old Oct 8, 2008 | 12:47 PM
jimmy o.'s Avatar
i found a rubber grommet above the crank pully behind it was a bolt is this the tensioner bolt?
Old Oct 8, 2008 | 01:28 PM
jimmy o.'s Avatar
Old Oct 8, 2008 | 02:26 PM
maxpower98's Avatar
yes that is the tensioner bolt. i would have to believe that that tensioner is bad. i have seen a few tensioner pulley bearings go bad and they tend to walk the belt off.
Old Oct 8, 2008 | 02:33 PM
postman's Avatar
Default Re: (maxpower98)
1.check all pulleys. tensioner,cam gears,water pump, crank gear.
2. do you have the spacers behind your crank gear correct. backwards or maybe missing
3. is something bent and or wobbly
4.take it to someone that can figure it out before catastrophe
Old Oct 8, 2008 | 04:47 PM
jimmy o.'s Avatar
the tensioner is fine i think i got it back on there and tight i wil update tommorow to see if that took care of it. I dont know if there are any spacers as i didnt build the motor just assembled the top end if it doesent work out i will just get someone to fix it
Old Oct 9, 2008 | 12:16 PM
jimmy o.'s Avatar
Default Re: (jimmy o.)
Well it tried to come off again i guess iwll have to let someone else fix her i have never had any luck doing my own timing belts anyway
bretthuff0
Dec 29, 2010 12:28 PM
JDM_SOHC
27
Sep 28, 2009 09:05 AM
omgwtfbbqcrx
Feb 16, 2006 09:38 PM
neumonik
Jun 20, 2005 02:43 PM
Shady Hills
Jul 24, 2004 09:40 PM
