BENT rear crossmember
Old Oct 7, 2008 | 06:11 PM
spens 91 Ef's Avatar
Default BENT rear crossmember
i need help i have a 91 civic whith a broken crossmember i dont know to much about the crossmember just hoping the cars not wrecked
Old Oct 7, 2008 | 06:31 PM
zrickety's Avatar
Default Re: BENT rear crossmember (spens 91 Ef)
it looks like you've started 3 threads with the same question...overkill.
you can clean it up and reinforce it with some metal and some welds. do you know if the frame is bent? you'll probably want to take it to a body shop and they can tell you if it's worth saving (it probably is)
Old Oct 7, 2008 | 06:32 PM
gringo7718's Avatar
The pic is not that great. Here is a pic so maybe you could describe where its bent using this photograph.
How did it happen?
Have you tried to get the car alligned?
Here is a pic of someone who had to reinforce theirs
Old Oct 7, 2008 | 11:43 PM
traxxasx's Avatar
If your talking about that little dent, i would not care.
Old Oct 8, 2008 | 05:40 AM
Default Re: BENT rear crossmember (zrickety)
the wheel thats on that side where the dent is the alignment is mest up
Old Oct 8, 2008 | 05:42 AM
Default Re: BENT rear crossmember (gringo7718)
i dont know i bought the car like that, i thought it was a bad strut thats why my alignment was mest up then i go under my car and find this
Old Oct 8, 2008 | 09:39 AM
EL Vap133's Avatar
Wait is that the rear engine cross member or the rear suspenion cross member?
Old Oct 8, 2008 | 09:41 AM
nickrps's Avatar
Default Re: BENT rear crossmember (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Wait is that the rear engine cross member or the rear suspenion cross member? </TD></TR></TABLE>
Exactly.
So which is it so we can help?
Old Oct 8, 2008 | 10:07 AM
it is the suspension, its a front wheel drive car
Old Oct 8, 2008 | 10:20 AM
Coltmorris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spens 91 Ef &raquo;</TD></TR><TR><TD CLASS="quote">it is the suspension, its a front wheel drive car</TD></TR></TABLE>
really?
Old Oct 8, 2008 | 10:59 AM
EL Vap133's Avatar
Really? Are you sure?
There are two rear cross members in the EF/ED. One is in the engine compartment towards the rear where your steering components go and the other is in the actual rear of the car where your rear lower control arms go.
Modified by EL Vap133 at 12:30 PM 10/8/2008
Old Oct 8, 2008 | 11:15 AM
its the only bar i see back there it connects to the control arms, and is bent on the left side
Old Oct 8, 2008 | 11:32 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spens 91 Ef &raquo;</TD></TR><TR><TD CLASS="quote">its the only bar i see back there it connects to the control arms, and is bent on the left side</TD></TR></TABLE>
Is it in the engine compartment or the rear of the car where your rear tires are at?
Old Oct 8, 2008 | 11:39 AM
Nutnwrench's Avatar
Looks like the rear of the vehicle to me where the rear LCA bolts up. If you have a hard hit to the wheel it can cause that LCA to push up into the rear subframe there and cause the damage he is describing. Sometimes you can just align for it but it isn't a huge deal for a body shop to pull the frame straight again. Just make sure if you have it straightened to have them weld some reinforcements into it so you don't have it moving again.
Old Oct 8, 2008 | 05:48 PM
im thinking about pulling it out my self then finding a welder and welding a support or just a peice of metal over it, anybody have some ideas how i can pull it out.
Old Oct 8, 2008 | 07:49 PM
jpciii's Avatar
Nobody knows what you are talking about. You need to provide better pics or a better description. Exactly what is wrong with the alignment?
Old Oct 8, 2008 | 08:52 PM
SovXietday's Avatar
Default Re: (SIred91)
What the hell, did you take that picture in the depths of the Pacific Ocean? Christ, I can't see ****.
Old Oct 9, 2008 | 05:37 AM
Default Re: (SovXietday)
i was under my car with my phone about 3 inches from the bar so it was hard to take a good picture, theres somebody who posted pictures on here it looks like the first one and the dent is on the left side
Old Oct 9, 2008 | 07:24 AM
CRX Toad's Avatar
<FONT SIZE="5"> IS IT THE FRONT OF THE CAR WHERE THE MOTOR IS? OR THE BACK OF THE CAR WHERE THE HATCH/TRUNK IS?</FONT>
Old Oct 9, 2008 | 07:39 AM
SIred91's Avatar
Rainman
Default Re: BENT rear crossmember (CRX Toad)
<U>HE MEANS THE REAR OF THE CAR PEOPLE, FOR PETES SAKE!</U>
The confusion being that he used "rear crossmember"
Should have said "rear suspension brace"
Old Oct 9, 2008 | 07:41 AM
SIred91's Avatar
Rainman
Default Re: (spens 91 Ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spens 91 Ef &raquo;</TD></TR><TR><TD CLASS="quote">i was under my car with my phone about 3 inches from the bar so it was hard to take a good picture, theres somebody who posted pictures on here it looks like the first one and the dent is on the left side</TD></TR></TABLE>
You need to be more clear, and people need better reading comprehension.
Take it to a body shop and have it straightened, then weld on some plates to keep it from deforming again, or if you can do that yourself, it will save a lot of money, but the car is far from unuseable.
You can fix it.
Old Oct 9, 2008 | 08:17 AM
ozrednsx's Avatar
[QUOTE=gringo7718]The pic is not that great. Here is a pic so maybe you could describe where its bent using this photograph.
How did it happen?
[/QUOTE
Well anyway the pictures ^^^^ are not subframe reinforcements. They are Progress's rear swaybar brackets that utilize that location instead of the oem location. (first pic is my car)
You should try getting a ASR subframe brace and make it fit. I believe MarlonT (SIRmarlon on jdmu) has done so and would probably help but i believe its pricey and doesnt exactly bolt on i think.
http://www.jdmuniverse.com/for...s.jpg
Modified by ozrednsx at 9:25 AM 10/9/2008
Old Oct 9, 2008 | 12:52 PM
Default Re: BENT rear crossmember (SIred91)
i was looking in my owners manual about my car it said crossmember so sorry
Old Oct 9, 2008 | 12:54 PM
i didint do it i dont know how it happened i bout the car like this
Old Oct 9, 2008 | 01:19 PM
here are some new pictures
