question about GREDDY blue box?
i just bought a complete greddy tdo5 turbo kit, that is made for a 96+ gsr. and it will be going on a 92 jdm b16 motor, in a 92 civic h/b.my ? is will the BLUE box work on this motor?and if so, what would i have to do to make this motor/turbo run properly?
Thanks for the help
Thanks for the help
The Greddy Blue boxes bascially interchangable to a point. So long the box connects to your ECU plugs then it should work. The map for the fuel, ignition, and timing will be different for each vehicle though. Because it's for a GSR it may make the B16 run richer than normal. Connect it to a V-AFC <to trim the fuel> and it should work ok. Until you get the proper one or a standalone.
The Greddy Blue box is better than everyone thinks. Most failures I've seen come from user error. For a plug and play control box, it's pretty darn good.
i opened up my old blue box and saw that inside it's just a series of potentiometers...i bet w/ the schematics you could just adjust those to custom tune the fuel curve....
