do i need bigger injectors for a turbocharged stock motor?
Old Oct 7, 2008 | 08:46 AM
knightryderz's Avatar
Default do i need bigger injectors for a turbocharged stock motor?
is it necessary to have bigger injectors for a turbocharged stock motor? will a 255 walboro in tank fuel pump be enough for the stock motor? i want power but also want to be safe. let me know what you think or know.
Old Oct 7, 2008 | 08:51 AM
SovXietday's Avatar
Default Re: do i need bigger injectors for a turbocharged stock motor? (knightryderz)
Absolutely.
Do some research using your power goals as to what size you will need. There is more than enough info on this site through searching that you will find what you need.
Old Oct 7, 2008 | 08:53 AM
totsie7944's Avatar
Default Re: do i need bigger injectors for a turbocharged stock motor? (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">Absolutely.
Do some research using your power goals as to what size you will need. There is more than enough info on this site through searching that you will find what you need.</TD></TR></TABLE>
I couldn't agree more..this isn't really something we can answer for you. You need to research and figure out your build, power goals, etc...and then go from there.
Old Oct 7, 2008 | 09:12 AM
thanks for the info.
Old Oct 7, 2008 | 09:38 AM
Schister66's Avatar
Man U FTW
The general rule of thumb is that you need approximately 6cc of injector per whp. Using that guideline, your stock injectors will only allow you to make 160-180whp. If you plan to make more than that, you'll have to go bigger...
Old Oct 9, 2008 | 05:58 AM
i learn something new every day on these forums. thanks.
jonnydbagz
Oct 6, 2008 10:00 AM
ccssk8ter11
Feb 13, 2008 07:05 PM
b_serious
Feb 17, 2006 12:41 PM
drunknbass
Jun 11, 2005 11:45 AM
DsMWookie
Sep 6, 2003 06:25 AM
