piston question
Old Oct 7, 2008 | 06:27 AM
Unseen Racer's Avatar
Default piston question
whats better
SRP D16Y8 : 75mm - 9.1:1 compression
SRP D16Y8 : 75.25mm - 9.1:1 compression
SRP D16Y8 : 75.5mm - 9.1:1 compression
SRP D16Y8 : 75mm - 10.5:1 compression
OR
SRP D16Y8 : 75.5mm - 10.5:1 compression
Old Oct 7, 2008 | 06:49 AM
00b20vtecoupe's Avatar
Default Re: piston question (Unseen Racer)
better for wat? that question is horrible what are you building an all motor setup? or turbo? or wat...
Old Oct 7, 2008 | 06:56 AM
reactone's Avatar
Default Re: piston question (00b20vtecoupe)
The first 3 you listed are identical except for the bore size. If your cylinder walls are damaged, you would need a bore along with a hone. If not, the 75mm would be ideal. The other 2 are just stupid, for forced induction OR all motor. 10.5:1 is weaksauce.
CRX_Control
Oct 20, 2004 02:58 PM
dropgear
Dec 23, 2003 07:59 PM
