HELP!! idle speed fluctuates
Old Jul 27, 2002 | 09:26 PM
dsd7734's Avatar
Default HELP!! idle speed fluctuates
I've got a '98 Accord EX V6. The idle speed fluctuates between about 1100-1600 RPM every few seconds (but not all the time). This can happen when the engine is hot or cold.
The MIL (check engine) light comes on and I got an OBD II reader that says code P0505 - Idle Control System Malfuction. There is not a code present that says it's a bad IAC valve and the factory manual basically says it's either an idle adjustment (because the idle is too high, but this is not the problem) or the IAC valve.
Has anybody had this problem??
HELP!!!!
Thanks!!!!
Old Jul 28, 2002 | 03:02 AM
Big James's Avatar
New User
Default Re: HELP!! idle speed fluctuates (dsd7734)
I had this problem on my 94. Removing the IAC and cleaning it helped.
Old Jul 28, 2002 | 04:48 AM
Chiovnidca's Avatar
That's usually the IAC valve.
mwb928
Aug 18, 2015 01:21 PM
frostykue
Mar 28, 2013 08:29 PM
accord99power
Oct 14, 2008 04:39 PM
morales232002
Aug 13, 2005 04:07 AM
Victor
Dec 1, 2004 10:29 AM
