I want to put a cam on my jdm d15b vtec
Old Oct 6, 2008 | 07:59 PM
1990EFHATCH's Avatar
Default I want to put a cam on my jdm d15b vtec
whats the best cam out there for my jdm d15b vtec? and what elso do i need for my cam swap?
Old Oct 6, 2008 | 08:05 PM
gator88's Avatar
Default Re: I want to put a cam on my jdm d15b vtec (1990EFHATCH)
one with 1" lift. Will sound like a built Z06.
What do you do with the car, why do you need a cam, what valvetrain modifications. We need info and you need research.
Old Oct 6, 2008 | 08:09 PM
Default Re: I want to put a cam on my jdm d15b vtec (gator88)
Drive it from school, work, girlfriends house, places, have fun with it. I want more power its a stock jdm d15b vtec w/intake, headers, exhaust
Old Oct 6, 2008 | 08:56 PM
Radim's Avatar
From what i hear the D15B cam is better than the Z6 cam, not sure about the Y8 cam. Just keep the D15B cam on and run premium gas.
Old Oct 6, 2008 | 09:14 PM
Default Re: I want to put a cam on my jdm d15b vtec (Radim)
I PUT 93 OCTANE BUT I WNAT MORE POWER W/O BOOSTING IT GRACIAS
Old Oct 6, 2008 | 10:05 PM
tico's Avatar
good luck with that. u dont need a cam unless ur draging alot. aggresive cams make a daily sound like ****. a good way to get some extra little power would be a lightened flywheel wont gain but maybe 1hp but urr acceleration will benifit. get a hondata intake manifold gasket. up to 17degrees cooler in the manifold. like 60 bucks for that. also i have heard u can keep ur stock cam but upgrade the valvetrain run slightly thicker oil and a jdm B-series ecu and u can make good top and mid power, but like i said thats what i have heard
Old Oct 6, 2008 | 10:48 PM
Radim's Avatar
Default Re: (tico)
DOHC ZC then, cams are expensive. You can probably find a DOHC ZC for around 200-400.
Old Oct 7, 2008 | 01:26 AM
143MYVTECEF's Avatar
Default Re: (Radim)
Google is you friend. d-series.org will give you a lot of help. These companies all make cams for Sohc Vtec powerplant:
Crower
Zex
Exospeed
Gude
Web
JG
Exospeed
Skunk2
Akmee
comp
crane
Old Oct 7, 2008 | 11:11 PM
MustB18's Avatar
D15B CAM IS THE BEST ONE . Just stick to it and spray 55 shot and build the head
Old Oct 25, 2008 | 03:26 PM
Bsixteen_CRX's Avatar
Default Re: (MustB18)
anyone got any results they can post for the bisimoto stage 2 cam for the z6 or any bisimoto cam for that matter. i want to put one in my d15b.
shosek03
14
Mar 21, 2008 04:11 PM
1slowEF9
Nov 14, 2006 01:21 PM
BoostinZc93
Oct 26, 2006 03:10 PM
NirVTEC
Mar 28, 2006 04:44 PM
fwdftw
Jan 19, 2005 06:07 PM
