loose gearbox
Depending on the problem, it could be as simple as a worn return spring. It could also be a trashed gearshift drum, in which case you're looking at a lot of labor to pull the motor and split the cases. Take it to a REPUTABLE shop and have it checked out, if changing the oil does not make it feel any different.
93 900 Cbr, when I shift the the pedal it feels loose; How do I determine whats wrong? How do I change the Problem? My gearbox does not feel as tight anymore.
sup ryan
