NEVER again. Window Tint!
Old Oct 6, 2008 | 04:54 PM
z6htch's Avatar
Default NEVER again. Window Tint!
Okay so never again... I never want to touch, look at, or take off window tint again lol. My fingers are numb and my wrists are sore.
I had purple tint on my hatch, but it took me 2 and half hours just to do the hatch glass today.
The side windows are tomorrow!
Do any of you have suggestions for them to be easier?
Thanks
Old Oct 6, 2008 | 04:55 PM
The Collin's Avatar
Heat gun and a razor.
Old Oct 6, 2008 | 05:06 PM
blinx9900's Avatar
Default Re: (99_hb_on_air)
take it to a shop, $60 and they will remove it.
Old Oct 6, 2008 | 05:14 PM
The Collin's Avatar
$60? wow, CA must rape you guys on tint.
I had all my tint removed from 5 windows, and 15% Llumar (best tint there is) installed for $120. Lifetime warranty,also.
But if you don't want to do it yourself anymore, and it's that much of a pain, find a local,reputable shop to do it for you.
Old Oct 6, 2008 | 05:47 PM
Memnoch's Avatar
Default Re: NEVER again. Window Tint! (z6htch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6htch &raquo;</TD></TR><TR><TD CLASS="quote">Okay so never again... I never want to touch, look at, or take off window tint again lol. My fingers are numb and my wrists are sore.
Thanks</TD></TR></TABLE>
https://honda-tech.com/zerothread/2171028
Old Oct 6, 2008 | 06:26 PM
punkinbeck's Avatar
Rip it off.. Then spray glass cleaner on the adhesive.. Then take it off with a razor blade.. It comes off very easy.. turns into goo... just makes a mess
Old Oct 6, 2008 | 11:25 PM
NOFX's Avatar
H-T White Ops
Default Re: NEVER again. Window Tint! (punkinbeck)
Rear's got to be the worse with the defroster lines.
Old Oct 6, 2008 | 11:32 PM
EKwillister's Avatar
Default Re: (blinx9900)
$60 is hella expensive. There's a place fairly close that removes tint for $10.
Old Oct 7, 2008 | 12:10 AM
blinx9900's Avatar
Default Re: (EKwillister)
It was a guess people stop orgasming, i **** $60, and everybody with a fixed up car should be able to too (unless your in a state with low cost of living)...
Old Oct 7, 2008 | 06:04 AM
zer0.'s Avatar
I've never had a hard time removing tint...that glue is nasty though,haha! I used soap/water mixure with a razor blade and finished it up with goo gone.
Old Oct 7, 2008 | 06:32 AM
fryguy190's Avatar
Default Re: (zer0.)
wow... i never thought about using the goo gone...
i had a buddy that worked at an audio and tint place. they had this acid/water mix that was great. the only thing is though is i had to use 3 air fresheners at once for a week or two. and drive with the windows down. b4 i got my car tinted.
Old Oct 7, 2008 | 07:53 AM
Mrmatt3465's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">It was a guess people stop orgasming, i **** $60, and everybody with a fixed up car should be able to too (unless your in a state with low cost of living)... </TD></TR></TABLE>
My gosh I thought I was the only one who pisses money onto their car
Razor blade and glass cleaner works awesome after you get the tint off.
Old Oct 7, 2008 | 08:15 AM
naRIPSTA's Avatar
I am my avatar
At least you did the rears first.
Side windows are easy.
Old Oct 7, 2008 | 09:34 AM
mikehawk's Avatar
Default Re: (naRIPSTA)
I pulled tint off a 4 door teg in less than an hr .. with a CAN of glass cleaner and a razor. Make sure you have a lot of blades and change them regularly. I went through about 10-12
Old Oct 7, 2008 | 09:47 AM
scootibum's Avatar
20 bucks for mine to be taken off
Old Oct 7, 2008 | 10:46 AM
marks97el's Avatar
The DIY for removing tint would be great for you if you lived in a place where you still had really hot and sunny days. If you don't try this method.
I think what might make it a bit easier is making a solution of 50% ammonia, 50% water, then a squirt or two of shampoo.
Protect surrounding areas very well as the ammonia may cause some damage to vinyl and what not.
Spray window with ammonia, water, soap solution, and immediatley cover with a sheet of plastic (garbage bag will work). Let it sit for a while. 30 mins should be fine. In theory the ammonia will absorb into the tint and break down the adhesive and make it easier to pull off.
After you pull off the tint, spray remaining glue on the window with a foaming window cleaner. Let it sit for a minute, then scrape off with a razor blade. If you don't have a razor blade just use a scrubbing sponge that you would use for scrubbing baked on lasagne from your dishes (you know the yellow and green sponges).
If you don't have a foaming window cleaner, the regular kind of window cleaner will also do the job, just might take a little bit longer.
A little tip with the garbage bag, Trim it to size of the window. Spray the window with plain water, put the garbage bag up and then trim it down.
Something you could do to aid in this process to use a heat gun and heat up the window (from the outside) while the ammonia solution and garbage bag are on the window.
I have had success with this method.
Old Oct 7, 2008 | 11:03 AM
z6htch's Avatar
Thanks guys lol. I'm going to try the ammonia and garbage bag technique soon let you know how it goes sometime tonight.
I'm in a VERY slow build with no job. I was gonna make a thread for it but i know people will flame for the slow progress.
I managed to pick up a greddy evo exhaust though lol.
If you think i should start a build thread in the appearence build section let me know
Old Oct 7, 2008 | 11:26 AM
slo_hatch's Avatar
Default Re: NEVER again. Window Tint! (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">Rear's got to be the worse with the defroster lines.</TD></TR></TABLE>
x2. it takes twice as long for just the rear hatch glass than what it does for the side windows and quarter windows.
Old Oct 7, 2008 | 11:32 AM
EJ8_Enthusiast's Avatar
@blinx: if you **** 60 bucks, could you **** it my way - I have been wanting to get a K&N air filter but my **** just comes out as urine - and they looked at me funny when I tried paying with it.
Old Oct 7, 2008 | 11:58 AM
IP RACING's Avatar
Default Re: (EJ8_Enthusiast)
a lot of tint shops will charge you maybe 20bucks if you get the windows re tinted but just removing tint Ive gotten quotes from 30 to 50 bucks In my area
Old Oct 7, 2008 | 02:53 PM
pine_apple45's Avatar
Default Re: (IP RACING)
mMm purple tint..those suck! but at the tint shop i work at i use baby soap&water mixture with a few razor blades for the windows that dont have defroster lines. the windows with defroster lines i use a steamer but if you dont have a steamer and its a nice hot sunny day out. get a big black garbage bag, cut it out to the size of the window, spray some of the baby soap n water on the inside(where the tint is) and place the bag on the film and sit it outside in the sun for a while, then if it sat thee long enough and you go and peel the film off there shouldnt b much glue. and if there is glue left over grab a sos pad(the one w/out the soap in em is better cause the ones with soap in em can stain interior) and some 409, spray the 409 on it, let it soak then spray it again and start scrubbing.
hope it wasnt too confusing...GL
Old Oct 7, 2008 | 03:07 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
if you have a steamer you can use that. The tint just needs lots and lots of moisture. If your careful you can use a steam iron....kinda ghetto. Point is you need a lot of heated moisture
Old Oct 7, 2008 | 04:57 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8_Enthusiast &raquo;</TD></TR><TR><TD CLASS="quote">@blinx: if you **** 60 bucks, could you **** it my way - I have been wanting to get a K&N air filter but my **** just comes out as urine - and they looked at me funny when I tried paying with it. </TD></TR></TABLE>
Ya know i was about to do it but i just saw your older than me so you should have more flow i am not beyond giving parts away to strangers online, i have done it before...
Old Oct 7, 2008 | 05:20 PM
GuCBlackEk's Avatar
i agree, i will never get tint for my ride ever.
goldfinger93030's Avatar
just use a steam gun (the kind they use on tv to iron cloths) it should peel right off
