compression raito junk
Hello everyone, I am in the process of building a motor and i need some help understanding exactly whats going on. So i drive a civic, i was running a gsr motor, turbo (17lbs) with 9:1 comp pistons. Unfortunately i ended up cracking the cylinder walls so its time to get it sleeved. I searching for a better understand of compression ratios. I am trying to figure out basically what my effective ratio will be given certain variables. I plan on using a stock HG. I want to figure out what setup will be best. Higher CR pistons and lower boost, lower CR pistons and higher boost? And once i am able to work out the effective CR, how can i decide what i can boost to safely on pump gas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T »</TD></TR><TR><TD CLASS="quote">Hello everyone, I am in the process of building a motor and i need some help understanding exactly whats going on. So i drive a civic, i was running a gsr motor, turbo (17lbs) with 9:1 comp pistons. Unfortunately i ended up cracking the cylinder walls so its time to get it sleeved. I searching for a better understand of compression ratios. I am trying to figure out basically what my effective ratio will be given certain variables. I plan on using a stock HG. I want to figure out what setup will be best. Higher CR pistons and lower boost, lower CR pistons and higher boost? And once i am able to work out the effective CR, how can i decide what i can boost to safely on pump gas? </TD></TR></TABLE>
its time for you to pick up your copy of
it will explain things very effectively for you and its pretty spot on.
but the reason you crack a wall is because of cyclinder pressures getting to high. you probably truely didnt know your CR, which happens from time to time
ordered
I have lost all my trust in any shops ability for build a proper engine, so this time if it goes to ****...ill have no one else to blame
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T »</TD></TR><TR><TD CLASS="quote">ordered
so true
edit* i see your from van as well. whered you get your motor built??
</TD></TR></TABLE>so true
also this might help you figure out your comp ratio's an stuff. been pretty helpful to me so far
http://www.zealautowerks.com/
scspeed
Sep 18, 2008 02:26 PM
RTst92
Mar 5, 2006 01:56 PM
