240HP & 6-Speed
So I hear the new Accords will be fitted with an updated 240HP 3.0L V6, mated to a 6-Speed manual tranny. Sounds a similar to the Acura CL Coupe.
Think it'll be a hotrod?
it's an accord....the only reason they probably upped the power was cuz they made it a good 500 pounds heavier and needed the extra power to haul it's lanky *** around....so no!...it won't be a hotrod!
its definately a 3.0 iVTEC motor pumping out 240 hp, lame *** nissan could only make 240 with a freakin 3.5 liter.
Nissan lame 3.5 can make 280HP. Not a lot but honda havent made any 3.5 to surpass 240 hp. Not to mention the torque on the Nissam 3.5 is still higher then honda 3.5
please dont trash on Nissan
the nissan motor is a dohc engine with variable valve timing
honda has one of those...3.2L...290 hp....get the picture?
Is just that Nissan isnt lame manufacture as someone said. Their cars make good torque too.
3.5 infinity QX4 260 pounds
3.5 honda pilot 242 pounds
3.5 acura MDX 245 pounds
3.5 lame altima still 246 pounds.
[quote]Nissan has some good cars (350Z, Skyline) but their other cars are cammed for torque. Honda tends to get cars with a well balanced cam for the application. Also the bore/stroke ratios are needed to make the comparison. Not every 3.5L V6 is the same.[quote]
I know, even the 350 Z has different bore/stroke then the maxima 3.5.
I just dont like people to trash other car manucfacture so i wanted to bring some quality facts to prove them wrong. Anyway i knwo there are always some of those stupid *** holes.
all of honda's 3.5L engines are SOHC...the nissan motors you speak of are dohc...its a diff situation...
thats why the nsx motor is the only one to use as comparison...3.2L DOHC VTEC...290 hp...thats all there is to it...
Actually the VQ35DE engine in the 350Z and Maxima has the same bore/stroke, just different levels of tune. Now Nissan just needs to make a VQ35VETT, for those in the know.
it won't be ivtec...atleast that's my guess
just a modified J30A1 still 3.0...the torque isn't there to be any bigger than a 3.0
no its going to be ivtec, thats how it made the extra +40 hp using the same displacement.
umm lanky implies long and thin, synonymous with the word Lean, bad diction.
I was doing some comparison on the acura web site, nissan maxima has 3500cc and 3.76 x 3.21 while the 350Z is 3498 and 3.66 x 2.89. Maybe the data in their is not accurate, but i would like to see if this is true or not. It seems that nissan has more then one 3.5 v6 motor.
Honda 3.5 (oddysey, pilot, mdx) are very comparable to (maxima,altima, path, QX)
Dont be so sensitive, i wasnt trying to put honda down at all. Honda has it advantage so does nissan.
How did u know that they have the same bore/stroke?
nissan
