fuel filter problem
Old Oct 6, 2008 | 11:18 AM
casper.hughes's Avatar
Default problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
alright i have a 94 accord and the fuel line is seized on the filter what woul u recommend i doo i starteded taking the hole line off and i got to the joint in the back and its seized to so do i take the joint loose from the frame and were does it go from there thanx
Modified by casper.hughes at 12:25 PM 10/6/2008
Old Oct 6, 2008 | 03:35 PM
b18crx's Avatar
Default Re: problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!! (casper.hughes)
fuel filter should be inside the tank.
Old Oct 6, 2008 | 03:40 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!! (b18crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18crx &raquo;</TD></TR><TR><TD CLASS="quote">fuel filter should be inside the tank. </TD></TR></TABLE>
nope, not on the 94-97 Accords. Look in the FAQ for the how-to to see where it mounted.
Old Oct 6, 2008 | 03:41 PM
H-T Order of Merit
have you tried any PB Blaster or anything like it to help loosen any rust or whatever has it seized?
What tools are you using? If you aren't using a flare nut wrench get one of those and try that, you can get a better grip on the fittings with those.
Old Oct 6, 2008 | 03:55 PM
hondadude's Avatar
Maybe this link will help you ;
http://www.freewebs.com/hondad...r.htm
Old Oct 6, 2008 | 04:34 PM
H-T Order of Merit
Default Re: problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!! (hondadude)
haha, I thought having a link in the FAQ was easy already but you just had to make it easier didn't you just kidding, nice to see you around again
FloridaCivic
Feb 25, 2007 10:08 AM
CBURKE
Jul 26, 2006 06:30 AM
Mike813
Oct 24, 2003 02:54 PM
Kid1320
Sep 19, 2003 12:51 PM
AK94GSR
Aug 7, 2002 08:02 PM
